dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,586
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
i run higher ratios and do not have heavy buildup on my exhaust port. Most of what you talk about it the older two stroke and conventional oil two strokes not the good synthetics. Good synthetic oil used even at ratios of 32:1 or 40:1 in place of 50:1 will actually start to remove and reduce some of those deposits. not all but some.
Mostly I see it in pro saws, like the Husky 266 I just opened up. These are run a lot more than most of our saws,
using 50:1 conventional JASO-FD semi-synthetic oil. Owners manuals of some pro saws do mention that chainsaws
need their exhaust ports and mufflers cleaned as scheduled maintenance.
In the 2-stroke racing world, 32:1 full synth is often used, but tear-down and de-carboning is called for very
often. Power valves can clog up with this oily soot, which is actually abrasive. I often see the first scoring on
chainsaw pistons occur right next to the exh port where the soot "stalagmites" grow.
