Canned Gasoline?
   / Canned Gasoline? #131
pic looks like terrible quality. I can see the carbon hunks you talk about but the piston looks good on this pic at least? Looks a bit drythough! as does the exhaust port. I would rater see a wet exhaust so that you know that the oil is making it all the way to the exhaust side of the piston. Thats what most of us saw guys like to see is that telltale small trail of wet exhaust. A dry piston is not very lubed.
   / Canned Gasoline? #132
The dry look is most likely due to how long this unit sat before I got it. There are small scratches on
the piston below the lower ring, but it was prob caught in time. I suspect the cyl, piston, and maybe
even rings may still be OK. I never removed this jug. Sold it for parts.
   / Canned Gasoline? #133
Never seen nor heard of this before....
   / Canned Gasoline? #134
You would think the price would come down with the price of oil now.
   / Canned Gasoline? #135
Nah.... Convenience factor.... Just like buying tickets for anything online....
   / Canned Gasoline? #136
Priced Stihl Motomix at the dealer this afternoon and was floored when told the 5 gallon jug is priced at $150
$30 a gallon for fuel and they said it sells!
   / Canned Gasoline?
Baileys is a whole lot cheaper and they are in your state.
   / Canned Gasoline? #138
Hasn't any one tried racing gas?
I have been tempted but haven't seen the prices but I'd bet its cheaper than premixed in the stores.
Sunoco supreme is available at a local motorcycle shop in 5 gallon pails i might have to try it.
Sunoco® Supreme™ is a 112 octane leaded race fuel designed for competition engines routinely operating over 7000 rpm. Supreme is blended to achieve a high motor octane number and fast burn speed to ensure engine protection lap after lap and pass after pass. It features a comprehensive additive package to enhance shelf life by improving storage stability and minimizing oxidation. Sunoco Supreme is designed for compression ratios up to about 15:1 in small block V8s, and can tolerate higher compression ratios in smaller or more efficient combustion chambers. Supreme’s fast burn speed also makes it a popular choice for 2-stroke applications.
As with any gasoline, Sunoco Supreme should be stored in opaque, tightly sealed containers and kept where temperatures are stable. Properly stored, the shelf life of Supreme is in excess of 3 years.
Disclaimer:
Legal in California only for racing vehicles in sanctioned racing events.
Legal:
For off-road and racing applications only.
Sunoco Race Fuels | Supreme
tom
   / Canned Gasoline? #139
I just checked 5 gallons of 260GT non lead no ethanol $69.00 for 5 gallons = $13.8 a gallon
I think I'm going to try it next time i can get there to pick it up
Tom
Sunoco 260 GT is a street-legal, oxygenated, unleaded gasoline designed for high performance street cars, muscle cars, classics, street rods, motorcycles, and the like. With a 100 octane rating, Sunoco 260 GT will allow increased boost levels in supercharged or turbocharged applications compared to lower octane “pump” gas.
Sunoco 260 GT will not harm catalytic converters or oxygen sensors. 260 GT contains a comprehensive additive package for greater engine protection and reduced fuel system deposits. It is compatible with two-stroke synthetic and mineral-based engine oils. As with any gasoline, it should be stored in opaque, tightly sealed containers and kept where temperatures are stable. Properly stored, the shelf life of 260 GT is in excess of 1 year.
Disclaimer:
Legal:
Most states
   / Canned Gasoline? #140
I just came across the old manual for my very old Echo Brush Cutter and it read 20 to 1 mix unless using Echo two-stroke and then 32 to 1 mix...
2013 Ford E350 Box Truck (A47384)
2013 Ford E350 Box...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
1968 International Harvester 856D 2WD Tractor (A50657)
1968 International...
2021 Doyle 8 Ton Trailer Tender (A52128)
2021 Doyle 8 Ton...
2013 Nissan Pathfinder SUV (A50324)
2013 Nissan...
2011 JOHN DEERE 329DT SKID STEER (A51242)
2011 JOHN DEERE...
