I CAN see while welding !!!!!!! Try this helmet !!!!
   / I CAN see while welding !!!!!!! Try this helmet !!!! #1
oldpilgrim
Elite Member
SE Ma
2014 Mahindra 3016HST
I started this so others who missed the I can't see thread might pick up on it.
In that thread, http://www.tractorbynet.com/forums/welding/351885-cant-see-when-welding.html , I and many others said they had a real hard time seeing much of anything when they are MIG welding.
I did some research and decided to try an ANTRA helmet that has adjustments all the way down to shade 5.
This is what I got:
Antra AH6-660-101S Solar Power Auto Darkening Welding Helmet with AntFi X60-6 Wide Shade Range 4/5-9/9-13 with Grinding Feature Extra lens covers Good for Arc Tig Mig Plasma CSA/ANSI Certified By Colts Lab - - Amazon.com
If that link doesn't work, search "AH6-660-101S" on Amazon.
It comes in three different lens sizes and multiple designs. Different sizes and different designs determine the final price. I got the middle sized lens and the skull design as I though it would be easier to find when I set it down somewhere. If you get basic black with the standard lens size, you can get it for as little as $59. My combo of size and color was $79 with free shipping...without PRIME !.
It has a selector switch which allows you to have 2 ranges of darkening. One setting gets you from shade 5 to shade 8. Flip a switch and you get shade 9 to 13. the individual shade is determined by an easy to reach outside knob located at your left temple. Turn the knob to 'grind' and it shuts of the darkener circuit and gives you a shade 4 for grinding. It comes with several outside clear lens covers and an additional inner lens cover. Also 2 spare batteries. I also ordered a 1.75 cheater lens.
The headband is easy to install, is easy to adjust and comfortable. If you flip the mask back over your heard, it stays there.
Now to the test.
I have a Hobart Handler 140 which has 5 amperages to the torch, labelled 1-5, so I don't know what amperage I actually use. I set it on 3. I set the shade on 9 and ran a bead down some scrap steel. As expected it was too dark, like my old helmet.
I cranked it down to 8 and I could see! I turned it down to 7 and I could see BETTER! Lower than that and it was too bright, but I'm positive a 5 or 6 would be perfect for OxyAcet torches.
So 7 or 8 was perfect for me. I could see the work and I could see the puddles perfectly. I put the cheater in and it helped a lot. I left my glasses on. I did not try it without the cheaters as what I saw was perfect as it is. There is no 'click' setting on the shades, so you can get an infinitely adjustable shade setting like 7.5 or 8.25 etc.
I didn't use it with my Lincoln AC tombstone but I'm sure it will be perfect with that when I figure the proper setting for it.
I am exceptionally happy with this helmet.
Try it, you hard of seeing guys. I bet you'll like it.
[h=1][/h]
   / I CAN see while welding !!!!!!! Try this helmet !!!! #4
Good to hear! I have the Hobart Handler 140 as well, guess I'll be adding that helmet to my Amazon wish list. Give us an update after you have used it more.
   / I CAN see while welding !!!!!!! Try this helmet !!!! #5
At least in the old style welding helmets;anything less than "9" is too light for most welding.You could damage your eyes by using too light of a lens.
   / I CAN see while welding !!!!!!! Try this helmet !!!! #6
Great to Hear,
I am still impressed with mine-, especially with the versatility (tig, Mig, Stick, Oxy-Acetylene, Plasma cut and grind) all with very good results. Hopefully California will get a chance to try his antra out in the near future
I did find that when mig welding in a well lit area it works good at 9-13, and tried a dark area on low amps @ 8.6 setting it could use a little external light. Since then have used mine at 9-13 for welding. Only on mig welding in a poorly lit area on low amps does it seem to need some extra light.
Did find this on Lincolns site:
Many people mistakenly think that the lens shade number corresponds to the amount of protection that is provided to the eyes and hence the higher the number, the better the protection. But in reality, all well-constructed quality welding lenses, have a screen that filters out 100 percent of the harmful ultraviolet (UV) and infrared (IR) wavelengths and provides protection to the eyes. The number just denotes the amount of darkness provided by that particular lens and should be used by operators as a guide to select the one that is most comfortable and yet provides good visibility for the particular application.
Arc weld has a point about combining cheater lenses with lower darkness settings -
I am super happy my new Antra, but will be careful with settings especially since i also use a cheater lens sometimes.
   / I CAN see while welding !!!!!!! Try this helmet !!!! #7
I hate to be captain obvious but a shade 7 lens and a 1.75 cheater might let you see better for the moment but not so much down the road.
   / I CAN see while welding !!!!!!! Try this helmet !!!! #8
... Hopefully California will get a chance to try his antra out in the near future
Ok, ok. :D I haven't broken anything, or needed to fabricate anything, recently so I haven't had a need to get out the welder. Here's what I've been tinkering on while it rained. And I got in a few hours on the tractor clearing runoff channels before the rain came back. When I have a couple of hours to tinker with welding I'll try out the helmet and report here.
   / I CAN see while welding !!!!!!! Try this helmet !!!! #9
My cheap helmet goes from 8 (or maybe 9) to 13. I often do low power mig welds so it's always at the lowest setting. On a couple of occasions I've cranked the power up and forgot to "darken" up the helmet. You can see the puddle great but as others have said it's not good for your eyes. Be careful with those low settings.
   / I CAN see while welding !!!!!!! Try this helmet !!!! #10
:D no pressure- looks like you have been busy
I will probably have to read-re-read that thread a couple times to get a picture of the wireless project
   / I CAN see while welding !!!!!!! Try this helmet !!!! #11
All modern welding helmets have permanent uv and ir filters. The darkening ability doesn't affect the safety of these helmets. If you're welding at max amperage and the setting is on minimum dark like 4 you aren't going to damage your eyes because the filters are protecting you. You MIGHT have some flash fatigue but it's doubtful.
This is a common misconception. The darkening feature is separate from the safety protection.
Auto darkening welding helmets are inherently better because of other reasons such as always having the lenses shading you instead of accidental arc strike (especially in stick welding) and having the helmet up and if you're welding around other welders you'll spend less time avoiding their arcs.
They also can help your accuracy while you practice and reduced fatigue and neck-flip soreness.
Also you can safely watch the puddle cool while still bright instead of flipping up to a white hot puddle that you'll stare at.
   / I CAN see while welding !!!!!!! Try this helmet !!!! #12
You might want to start at the end where I know a little more. I started that thread to ask questions and learn the details of using Ethernet over Powerline. This is a phantom Cat5 cable that uses a sender/receiver pair to deliver a signal through house wiring.
   / I CAN see while welding !!!!!!! Try this helmet !!!! #13
Ok, I got a chance to use the new Antra today.
I had a very small project, attach a replacement backhoe tooth 'cap', the wear part, that slips over the structural tooth. I practiced first on scrap steel plate that is about 0.090". My 'Century 130' mig welder runs on 110 volts, rated 105 amps DC output. I have it set up for flux core wire.
Like Dan above, around 8.6 on this helmet's lower range seemed right for my testing. I can see the puddle and a little of the bead being laid down without added lighting. Visibility with this small welder is comparable to using my 220v230a stick welder at 125 amps. This Century was sold mainly for autobody repair and can adjust down to lesser output so this is the right helmet for it.
Using the Antra I now have much better visibility than I saw with the HF Blue Flame helmet. That one claimed minimum setting 9 but it didn't adjust down far enough to use with this welder.
Thanks to everyone who encouraged me to buy the Antra!
   / I CAN see while welding !!!!!!! Try this helmet !!!! #14
Nothing wrong with auto-dark helmets but if you're using too light a shade, especially with a cheater lens, it's going to cause eye strain and eye fatigue. Long term effects, who knows but gambling with your eyes is the last thing anyone should do.
   / I CAN see while welding !!!!!!! Try this helmet !!!! #15
I'm so happy I saw this thread. "joefromga" comments explain the details not included in my Harbor Freight auto-darkening helmet. Based on this info, I think I can adjust to a lighter shade so I can see what I'm trying to weld. I'm very much a learner, so this helps a lot. I have a very inexpensive wire welder (HF) which my kids bought for my birthday a few years ago. I also have a Craftsman stick welder (220v) which I've been using while making needed repairs to my 16' utility trailer. Trying to see what I'm doing has been a real pain since I thought I had to have the lens real dark. Now I'll try a lighter setting -maybe I'll be able to see what I'm actually trying to weld. Thanks again. :cool2:
   / I CAN see while welding !!!!!!! Try this helmet !!!! #16
Set it lighter and weld a little then see if your eyes bother you over the next day or two. I use to keep my helmet set to a lighter setting but the next day my eyes felt itchy and dry. I now have it turned up. I can't see the puddle as well but my eyes no longer bother me. If I welded a lot I think I would try to find tune what level works best for me.
   / I CAN see while welding !!!!!!! Try this helmet !!!! #17
I learned this week that the light sensor is at the top of the lens.
So, when welding under a trailer fender my mask was being blocked by the fender like a sun visor and the auto darken lens wasn't darkening! It was just the usual green and I was getting some flash but still protected by the filter.
So, don't weld with the light sensor blocked or it won't darken.
   / I CAN see while welding !!!!!!! Try this helmet !!!! #18
I use both a Hobart Stickmate LX AC/DC welder and a Hobart Handler 140.
My helmet is a $60 autodarkening unit from Northern Tool set at 10 or 11 on the shading control.
I wear a pair of yellow tinted wraparound aviator sunglasses rated UV400 that reduces the glare from the arc and helps me see the puddle clearly. Also protects my eyes from reflected UV that can get inside the helmet from the rear.
   / I CAN see while welding !!!!!!! Try this helmet !!!! #19
I think that has happened to all of us if you weld around some kind of structure. That is why the more expensive models have 4 sensors distributed around the helmet.:)
   / I CAN see while welding !!!!!!! Try this helmet !!!! #20
Great For Arc, Mig, Tig, Plasma Applications with Grinding Feature<<<<<<<<<<<<<< Every time I look up these so called state the art welding helmets, the specs are vague to the point of scratching my head, does it dont it will it and is it .
I'd like a welding helmet with auto darkening lens about 2"x4", adjustable shade, need to be able to install a 1.50 cheater lens, and last but not least I need a replaceable CLEAR LENS for grinding, now is does this welding have this all theses features or no?
2020 Dodge Charger Sedan (A59231)
2020 Dodge Charger...
UNUSED FUTURE FT-ZDQ160 110V CONCRETE VIBRATOR (A60432)
UNUSED FUTURE...
2022 Ford F-150 Pickup Truck (A59230)
2022 Ford F-150...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
