SSQA pads fixed together vs not fixed together - why?
   / SSQA pads fixed together vs not fixed together - why? #21
The uneven pads will line up when you push against the attachment, raise it and rollback before locking the latch pins.
It often takes less effort to shove the attachment out of position than to get the "pads" to equalize against the attachment. I'll stick with my opinion that a non-rigid QA device is a cheaply made constant annoyance. An opinion based on unfortunate experiences with Deere FEL's.
It's never been an issue, and I change attachments enough to warrant $200 in parts to make it hydraulic.
Cast arms are heavy enough they don't bend. I'd say that makes them better. :)
Power will come from a second diverter on the front of the boom. I have a grapple circuit already - I'll run that to my diverter and the switched circuit will control the latches.
If I have the tools here to do it, I'm going to bring the SSQA mounts and the torque tube home. My cylinder is at home. It's a little guy with 6" stroke.
   / SSQA pads fixed together vs not fixed together - why? #23
I'd guess I could bend cast arms. It's not like a 3/8 steel arm bent under intended use.
I'll remember not to loan you anything. :p
   / SSQA pads fixed together vs not fixed together - why? #26
Pn: 9-8841 1.5x6x.75" 19" open/13" closed 3kpsi max
Thanks, I was curious about the end mounts:
End mounts, port locations, and even length of stroke mean little to me. ;)
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2019 CATERPILLAR 272D2 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
John Deere 2010 Loader Tractor (A50514)
John Deere 2010...
2016 John Deere 410E 40 Ton Articulated Off-Road Dump Truck (A50322)
2016 John Deere...
2004 Dodge Ram 1500 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
1267 (A50490)
1267 (A50490)
