IslandTractor
Super Star Member
- Joined
- Sep 15, 2005
- Messages
- 16,647
- Location
- Prudence Island, RI
- Tractor
- 2007 Kioti DK40se HST, Woods BH
Another vote for 3 range HST.
My first tractor was a Kioti CK20. 21hp. two range HST. very capable machine especially for loader work with something close to 1100lbs lift. It's Achilles heel was the 2 range HST when mowing. Low range was for stump pulling (which it did well...21hp was more than adequate) and high range was for traveling fast on flat ground. Problem for me was that my mowing was up and down hills. I had to drive up the hills in low and then switch to high to drive back down. A nuisance.
I would probably bump up one size range to get the 3 speed hst AND a loader that lifts more than 1000lbs. If you can find an older Kioti CK27 or CK30 those are very capable reliable tractors that cover both the desired hst and loader specs. The new Kioti I would look at is the CK2610 which does have three range hst and a 1250lb lift loader. I haven't priced the CK2610 but I would guess it sells for about the same as the Kubota B2601.
The Kubota B2601 is a nice tractor but really optimized for mowing IMO. It is very light compared to the others you are looking at and has the least powerful loader. It is more likely to be outgrown than "next size up" tractors.
