Looking for tractor to maintain 8.5 acres in NH
   / Looking for tractor to maintain 8.5 acres in NH #41
I have to disagree with Gladehound. A 60hp tractor for the use described is simply whacko. Maybe 40 tops but anything bigger is ridiculous for maintenance of 3.5 acres and a driveway that could reasonably be cared for with a 25-35hp tractor.
I gave my thoughts on tractors in the 20-60 hp range. I indicated that if it were me, I'd go with the 40-60hp range. I did not recommend that the OP do this. I just said, if it were me. I said this because I have 1 acre of lawn and 1 acre of woods and I went with a 45hp large frame CUT after owning a 20hp for 9 years and pushing it to max every time I used it. Snow removal took way to long and wore me out. The hydraulics were far to weak in the woods. There were several landscaping tasks that I simply could not do with that tractor due to the size of the rocks I was running into. 40 hp and 60hp CUTs are often on the same size, just a bigger engine. If I had HST, I wouldn't want any less than 60hp. I drove a 40hp HST and hated it because it was so sluggish compared to gear. I completely skipped the 25-35hp tractor range because being familiar with my cousin's JD4300, I thought there was a high probability that I would regret getting something in that range and that the step up needed to be bigger.
While my tractor size is good for my uses, I still wouldn't mind more hp. I guess I'm whacko. I've been called worse.
Why spend $40,000 of the guys money when $20K will do the job??
I never suggested that the OP spend $40K instead of $20K. Just over a year ago, I purchased a leftover 45hp tractor at a dealer with full 4yr warrantee, loader, rear remote and hydraulic reverser for $19.5K ($20.6K out the door) plus free delivery from over an hour away. The reason I laid out my thoughts on the different size tractors that might be considered is because there isn't much price difference. And now that the OP indicated that he has no aversion to gear, and a 20K budget, and is value minded... Well, he is exactly where I was a year ago.
$40K... for $40K you can get a Kioti RX7320 w FEL AND Cab without even negotiating. No sure why you went to $40K?
With New Hampshire snow, if you want a snow removal set up that can actually get you out your driveway on a heavy 3 ft snow, you are either going to need a blower or something big enough to walk through that snow. I have found no better way to remove deep heavy snow on gravel than with a high volume skid steer bucket (42" deep x 30+ inches high) with 3 edge tamers bolted on. But nothing smaller than a large frame CUT can handle that size bucket well.
My point is, if you plan to spend near $20K on a SCUT and instead you could get a 40-60HP tractor (maybe a left over) for similar money, to me it's a no brainer.
Hard to get one machine to do it all well. You will mow far more than you will do anything else.Zero turn would be on the top of my list. cut down mowing time by an hour per mowing or about 50 hours a year. That is a lot. Hard to say no to a loader but you could probably get by without one. A grader blade,boom pole,rough cut mower and a cheaper older tractor and you could get by. I think I would rethink my plan.
Great point. 100% agree. For the cost of a mower for a tractor, you can nearly buy a separate zero turn.
When I bought property, I bought a zero turn and waited a year to buy a loader just because I didn't have the money. The loader I bought was 20hp but even at that time I knew I wanted something twice that size. So I bought the smaller tractor used knowing I could always sell it for close to what I paid. 9 years later, I sold it for $1,200 (15%) less than I paid for it.
However, it sounds like the OP is using lawn mowing as a justification for a tractor to the wife. I think the OP needs to find better justification than lawn mowing.
How about wood gathering for the fire place, driveway maintenance, spreading gravel, snow removal (think mega storm), storm clean up, putting in a garden, digging out a foundation, putting in footers, lifting materials up to the roof, landscaping, putting in a ninja warrior course for the future kids, pulling the cable tight on that giant zip line project (also for the future kids), fixing future water drainage problems, putting in that fence she wants, unloading materials from trucks, bending a car door back so that it will close, moving large boulders that are inconveniently placed, expanding the driveway for more parking, clearing a little more woods for whatever reason - I am not just making things up... These are all things I've done with my tractors on my little 2 acre property. Most of which I did not foresee when purchasing my first tractor. Many of which fell into the "I wish I had more tractor" category when I had the 20hp and some still fall in the category with the 45hp (mostly the stubborn boulders).
You have a flat yard and given the time of year, the first real work you need to do is keep that lawn under control. What I really think you should do is buy a used commercial zero turn (since your yard is flat) and wait on the tractor / FEL until after you get into the place and have a better idea of everything you might want to do. You may even be able to save up some addition funds. Wait until a mega snow storm and ask your wife to help you shovel. When she looks like she's about to collapse in the snow, suggest to her that you buy a tractor so that you and her don't have to deal with this crap anymore - I'm betting that budget will go up. :thumbsup:
HST vs gear: Like most here I recommended HST before I knew your budget and that you had no aversion to gear. HST is truly much easier for new operators to get good on. That being said, you are young and have no issue with clutch work at this time. You are on a budget and looking for value. Slightly used (as in almost brand new) gear tractors is where the value is. Certain brands tend to give you more for your money and still have great reliability (Kioti and LS come to mind). You have time, so use it. You're not going to find a great deal over night. I looked for nearly a year before stumbling on what I thought was a good deal locally. So take you time. Most will insist on HST for loader work, what they don't tell you is that you can get a much stronger gear tractor for the same price. If you ever get a knee problem, you sell it and buy something else. No big deal. Trying to buy now, once for all time is a fools hope - none of us know what life will throw at us.
   / Looking for tractor to maintain 8.5 acres in NH #42
This is the web.
Address the OP's needs, pass on rebuttal to contributors.
Otherwise the thread get derailed and you get high blood pressure. Neither good.
   / Looking for tractor to maintain 8.5 acres in NH #43
Yes lots of great info and lots to process. 1 thing I've changed my mind about with the feedback so far is to get a 3pt finish mower instead of MMM. 2nd thing is I see the many benefits of a larger machine. Need to kinda start over on the research and find what might fit in my price range in the "compact" category.
I also know absolutely zip about any dealers in the area so I will have to go find some. Will be good to see some in person, and not having a house yet will keep me from impulse buying. :D
My comment about pricing - nothing out there on Kioti, Ls, massey ferguson, couldnt get new holland site to work. Have not even looked at JD because everything ive read says they are overpriced, and I will obviously be trying to get the best value.
Snowback thanks for the pics! I dont anticipate a lot of "woods" work, they've done a great job cleaning up my lot already, but grapple still high on the list.
And lastly I am getting the impression that New England prices are higher than elsewhere. I was pretty sure I would hit my $20K limit with just about any SCUT. I am optimistic that maybe I just need to talk to a dealer to get better pricing, but what i am reading around the forum is that we might just plain pay more in The northeast.
We wil see. This sounds like its going to end up being more about $$ than anything else.
For general pricing info, go to http://www.tractorhouse.com/
You will be able to compare asking prices there. Keep in mind that asking price is always negotiable.
I'm glad you seem to be moving away from SCUTs and I think you'll have no problem finding 25-35 hp CUTs in your price range. And I think this is a fine size to start with for your purposes. Maybe, it will be the right size for life, maybe it wont. luckily, tractors hold value really well - especially if you buy slightly used or leftovers/demos that the dealer just wants to move before they get too old. The leftover/demo route is a good way to go to skip initial depreciation and still get all the advantages of dealer support / full warrantee.
The tractor with loader in the link below is used, but barely used. It is the same as my tractor but with 5hp less. It's in NY and it should still have 2 years of drivetrain warrantee. A little far from you, but gives you an idea of the deals that are out there. It is just a matter of time to find a deal like this at a distance that makes sense for you. This has a hydraulic reverser so you do not need to clutch or come to a complete stop in order to change directions (although technically, you do come to a complete stop at some point during any direction change - sorry, had to write that. It's a tough crowd!). The main gear box on this tractor is not synchronized so you should completely stop before putting in the clutch and changing gears. However, it is not hard to double clutch / time shifts in the higher gears when in high range. The asking price is ~19K. I'd bet you can negotiate something better than that. The loader on this is rated at 2,761 pounds to 9 ft, and 3727 pounds at ground level (both at the pin). It has ~15 inches of ground clearance which is nice for snow. I wasn't looking for nearly my exact tractor when I found this. It just happens to be the best deal I saw anywhere near you.
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=9899423
This is just food for thought. I do think you should worry about a dedicated mower first.
   / Looking for tractor to maintain 8.5 acres in NH #44
The OP will need a rear blade for grading his 600' driveway!
He may try to plow his driveway with a blade for the first winter, and then...he will buy a blower!
I would suggest that he get something larger than the LS XJ2025.
I was thinking a land plane might be better for the driveway, but I agree, the XJ2025 is too small....I just included it because he asked about pricing on them.
   / Looking for tractor to maintain 8.5 acres in NH #45
This is the web.
I fundamentally disagree with this recommendation. Some of the best information comes out of the back and forth between contributors and the OP, being new to tractors, can learn a lot form reading the point / counter point discussions.
Misinformation should not go unchecked. Otherwise we will all just get dumber and dumber with time.
If anyone gets high blood pressure from this sort of back an forth, I recommend you stop reading and consult your physician. :)
   / Looking for tractor to maintain 8.5 acres in NH #46
This is the web. Address the OP's needs, pass on rebuttal to contributors. Otherwise the thread get derailed and you get high blood pressure. Neither good.
If we all agreed on what tractor the op needs then we could make a chart and save hundreds of these threads.
   / Looking for tractor to maintain 8.5 acres in NH #47
Y
I know there's been a lot of back and forth, but I did give you a way to get ballpark pricing on LS tractors....lots of their dealers list them on Craigslist with actual prices.
You can probably get a smaller CUT right around $20K....
https://detroit.craigslist.org/okl/grq/5462420542.html
Prices do vary regionally, but most often it's only a couple of hundred dollars (going off what folks report here).
   / Looking for tractor to maintain 8.5 acres in NH #48
I completely agree with Gladehound on this point even if he is a horsepower whacko.:laughing:
   / Looking for tractor to maintain 8.5 acres in NH #49
MB tractor would be another place to look.
Townline is my Kubota dealer of choice though probably fairly far from you.
2015 Audi A4 Sedan (A56859)
2015 Audi A4 Sedan...
2003 Freightliner FLD 120 Columbia (A56435)
2003 Freightliner...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
CASE 610 Sprayer System 2000 Gallons (A56436)
CASE 610 Sprayer...
Portable Restroom (A54865)
Portable Restroom...
