Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #3,061
A logger buddy just cuts a 3-4' limb to pound wedges. If he loses one, he just another.
Will
   / Tractors and wood! Show your pics #3,062
I just beat them in with my chainsaw... Heck, it's already the same color as my wedges anyway!
SR
If I had as many saws as you that's the way I would do it too :D
gg
   / Tractors and wood! Show your pics #3,064
Got one of those maple logs I posted pictures of a few weeks ago sawn this morning. Got about 150 board feet of 1x6x12'.
Here's a quick video of the Peterson ASM mill in operation.
Hope to saw the bigger log tomorrow morning.
   / Tractors and wood! Show your pics #3,065
It was mostly sunny and 60* today, so me and my friend, went out to my woodlot. I'm still clearing out storm damaged tree's, so firewood was todays project!
We cut a pretty good load of "mostly" hard maple,
And once we had the wagon heaped up,
We headed home,
and as it was still early in the day, we started splitting the load,
While we was out there, we did manage to do some target shooting too... SO, over all it was a pretty nice day!
SR
   / Tractors and wood! Show your pics #3,066
Do you cut 3 logs at once? I have never had much luck doing that. It causes my saw to bind.
   / Tractors and wood! Show your pics #3,067
We do it all the time, even more than 3, IF I can get them to lay right....
When I get them on the forks, I hold them "lightly", I want them to lay there under their own weight, with just enough tension from the grapple, to keep them safely in place.
Usually, the first cut evens them all up, and after that, they get cut to the target length of 20", all that once. Of course, if they are criss crossed, you have to cut them what ever way keeps you out of trouble.
SR
   / Tractors and wood! Show your pics #3,068
I don't own a tree felling lever, but have used one several times. It works on "smallish" trees (6" DBH or less), but I found it more trouble than it was worth on a decent sized tree. I found it not worth the trouble to carry around with me on my tree felling. If a tree was small enough for that to be effective, I usually had other ways of overcoming back lean. If I had a whole lot of smaller trees to fell, maybe I'd consider borrowing one to use while on that project.
I suppose it depends on the tree some what, too. I use the plastic wedges and find them very useful, especially on large (24" beech trees) where the fall has to be pretty specific, for what ever reason.
I was cutting one at least 30" on a fairly steep slope, with a lot of surrounding brush and other firewood candidates, one winter, on the edge of my apple orchard. I needed the tree to fall where it didn't seem to want to go. I was going to have to winch it out of the tree line and getting it limbed was going to be a PIA if I didn't drop it right. (it was complicated, but I was determined). The order of the cut with these trees was important as avoiding a hang up was part of the strategy. Beech spread out wide and hang up easily.
I hinged it carefully, checking the direction and nipping at it the get it right. I got the back cut 3 or 4 inches into the tree and then set one wedge. I tucked the bar in at each side of the back cut and as I cut in front of the thin edge of the wedge, I added 2 more wedges and put all three in as deep as they would go. I continued working the hinge and pounding on the wedges. Watching the base of the tree, it became apparent the tree wanted to pivot off the stump. That gave me the information I needed to tweak the hinge and work the wedges.
finally when the tree (she was a BIIIIG girl) was leaning in the right direction (the notch took more wedge), I wacked the wedges one more time and nipped at the edges of the hinge. The tree pirouetted about 30 degrees (prolly less but it was amazing none the less), pulled away from the wedges and dropped about where I wanted it to.
I worked up a real sweat thinking about and bringing that big girl down. Satisfied with not having killed myself or destroying apple trees, I called it a day. I would not have even attempted that cut with out wedges.
   / Tractors and wood! Show your pics #3,069
Hey, hey, hey. So how does this swing mill all of a sudden show up? (or did I just miss it prevoiously/)
   / Tractors and wood! Show your pics #3,070
I agree, wedges are a handy tool to have. I was commenting on the felling lever someone linked. I found very little use for one of those.
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
UNUSED Black Outdoor Patio Fabric Screen (A53117)
UNUSED Black...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
