New project 1967 Ford 5000
   / New project 1967 Ford 5000 #21
Re: New project 1975 Ford 5000
He missed an opportunity to use the FEL didn't he!!!! Explain that big hole in the driveway to the wife when she gets home from work!!!! :D
That was the IPA's fault......:laughing:
   / New project 1967 Ford 5000 #22
actually.....had to 'dig out welding table" :p
as for dragging me rear...we only have 17 ac and 1 transition that would drag and I would only try it with a cage and 4x4....or maybe a cage and chains ;)
so low is good, around here
by the way here is my Arse...what am I missing....for real...newbie style :confused3:
other than a back ho'
   / New project 1967 Ford 5000 #24
I think he is talking about a bunch of hydraulic remotes??or the second chain for the arms? ?
   / New project 1967 Ford 5000 #25
Looks like the adjustable doohicky attached to the axle replaces the chain.
   / New project 1967 Ford 5000 #26
Ooopppsss, sorry, I was on two threads at once and meant to post that pic on the other one. Gentleman bought a 3910 without 3pt. Sorry for the distraction. :(
:drink:
Not much to update, spent the day trying to figure out what was wrong/up with gauges
Tach worked, needle is broken/rusted off so for right now, I used a hot glue gun to glue on a paper clip (yes ghetto, until I figure everything else out and spring for a new dash) The metal was in no shape for solder etc...
I pulled the hood and stuff off to have access to wiring thanks to FEL, and pulled the harness, light switch and key out as a unit
because of paint, electrical tape and factory non stick wire covering I couldn't tell exactly what was going on so I stripped it all off and traced wires
biggest issues were the ground on the dash was unplugged and the switch wiring was fubar :confused2:
I ordered some wire loom tape and will wrap wire later when dash is replaced
of course the charge light was on, and after checking generator by shorting plugs and using voltmeter(it was fine nice steady reading that moved up with throttle)
after rewiring dash, it comes on with key in run position, goes off above like 800 rpms (checked with volt meter) under 800 rpms it drops to 12.8 or so and light comes on
SO far the 6 book set I downloaded has been spot on :thumbsup:
So now gas gage works, water temp moves and the warning lights work...I will save up for some Bling...(new dash/gauge panel)
ghetto needle
and stripped down and marked wire loom
the aux lighting wiring now works also!!!!
until next adventure...which will be exhaust and rubber fuel hoses
   / New project 1967 Ford 5000 #29
Thanks for the update. Welcome to tractor ownership!!!
If she is a 1967, she is older than me by a year :p and with how I feel...we will be very intimate friends :laughing::laughing:
2011 PETERBILT 367 TRI-DRIVE WITH TAG (A52472)
2011 PETERBILT 367...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A52577)
2016 WESTERN STAR...
2006 MACK CV713 KILL TRUCK AND TRAILER (A52472)
2006 MACK CV713...
2024 JOHN DEERE 9R440 LOT NUMBER 78 (A53084)
2024 JOHN DEERE...
HYSTER H50FT FORKLIFT (A52472)
HYSTER H50FT...
