can-am 2016 Defender HD10 review
/ can-am 2016 Defender HD10 review #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander1000 6x6, Ego lawn mower and shopping for tractor
This is a can-am 2016 HD10 Defender review. Hopefully I'll not screw this up to much! I'll attach a few photos but we didn't get the defender until late, and never used it with with wheels mounted. Some photos will be of the Rhino to give you an idea what we do with these machines..
This past fall we were replacing a 2009, 700 Rhino which was at the end of its life expectancy with us and over the years found it was very short on HP while operating it with pods and in snow. We had UTV-4S pods on it. (you call tracks) So we hoped for more power in a new machine and having quite expensive maintenance grief with Camoplast products, we'd not get them again. Please note, on all the various machines we've used over the years, we break, melt or create some kind of grief while doing the heavy work we do with them so this might not apply to you. We normally get machines another trail systems have tested to help lessen our problems but we need much more power and having a good BRP dealer here, we went with this new work machine offered by Can-am. Having good service is quite, quite important for us and we do darn little of that ourselves.. I've been grooming XC trails for over 15 years, all within the Lake Superior snow belt so machine problems are not new.. We average 230" here in town. Also note, this not "my machine" and I did not pay for it. I'm just a lowly employee who suggests we need this tool or that.. We try replacing our tow machines every 5 years.
-------------Review preamble--------
What we wanted was the more powerful motor and this 1000CC engine was re-geared and tuned for just that. More torque, less HP. Along with full cab including hard doors, glass windshield (all glass will be hard), wiper, heater etc, etc. Can-am apparently did not expect to sell these ASAP since most of the cab components we wanted were not yet available when we put her to work. These will be added when they become available. And the LT Apache pods which are similar to and large, like the UTV-4S are. Total package will cost us around 28K when completed. Our UTV's do not go out on a daily bases over the winter. We only use them when we have so much snow, that one fellow can not work it down fast enough and we need two machines out packing. Or if the weather turns usually cool and we feel the cab is required for safety sake. We don't like to use UTV's since they are much slower than our Grizzly (an ATV) can work. We do like to take it out if we need tools and people in the field for something special, like a tree is down. But then in the fall this machine will be out moving tools, people and supplies to remote work sites. A UTV is really how we get things done then! I'm not sure of the hours we put on her this winter, I'll check next time I'm in da shop.
-------------Finally the Defender review----------
The LT Apache pods after some initial grief, are doing great.
The cab visibility is great and so are the can-am door mirrors we got. We run a cab fan to help keep glass moisture under control.
Steering is effortless and you can even rotate the pods while static! Plus the adjustable steering wheel is nice.
I like the cab controls layout as well and the buttons are glove friendly.
Storage space on and in the dash is really, really nice for working characters like us. We got tools and paraphernalia everywhere!! The snap in-out tool box on the dash is fairly worthless. I added "knobs" to it so we could open it while wearing gloves. We hardly use it and may permanently take it out.
Seats are quite comfortable and we do sometimes spend 8 hours planted on them. (farm talk?) Also nice is the center flip down arm rest which is normally down and used as a arm rest for steering,. Seats also flip up for cab cleaning.
The rear work box is quite nice and has many holes along its top edge so we can add bungee cords to hold whatever in. It case you don't know, its made from HDPE plastic and I like that as feature well. We normally take tail gates off and leave them off forever. This one is designed just like a pickups and comes off in seconds. It's nice! But not sure at this point if we'll reinstall it.
Power is a a whole higher level than our lame old Rhino we retired!! Nonetheless, we do have its pedal right to the floor now and then. Of course we only use low gear while pulling loads.
I should add that removing panels so wiring and switch's can be added, has been quite easy. We found this machine has been easier to do that than the Rhino was.
------------Notes from the grief department--------
The vinyl covered, steel frame doors are worthless. The vinyl coverings won't stay attached to there Velcro plus the doors are just to hard shut or open to exit.
The intake on the CTV cooling system was plugged with snow within the first 500 ft and the hot belt warning light would flash shortly afterwards.. Funny we had a Defender here this fall which we zoomed right down to look at. While there I told the service manager that those intakes could not possibly stay cleared while operating in snow. So they subsequently rerouted the air duck into into the cab. Zero problems since.
We blew a gasket on the exhaust header. While investigating that, the dealer noted that heat was warping various heat shields above the motor. We are now awaiting new heat shields to test from Can-am. Portions of its exhaust system was wrapped in heat shield materiel which so far, has worked fine.
Fuel tank could be larger. Its tank is 10.5 gallons but if she's working hard, we'll have to bring an extra 5 gallon can along because we'll run it empty in to few of hours.
Shifting grief. From the beginning, we've had problem getting it into high gear. Its even came out of that while driving. The dealer has adjusted and adjusted it again. Hummmmmm We only use high when ferrying to a school about 1 mile away but nonetheless, this problem had been a real pain in the &^^%@)
What an I forgetting???
/ can-am 2016 Defender HD10 review #2
Thank you for the review. I test drove the Can-Am, and I like the machine but like every machine but the Yamaha Viking, the seats are uncomfortable with my fused lower back. I need a little more recline. I'm entertaining yanking the seat and trying to bolt in one of the sport seats from a Polaris.
/ can-am 2016 Defender HD10 review #3
I think I read the Wolverine seats would bolt into the Viking;need to remove the head rest.
/ can-am 2016 Defender HD10 review #4
I liked the Viking seats. I can tuck my legs up under the seats. Everything else's seats and I have issues.
Bad back issues: I would wish them on anybody.
/ can-am 2016 Defender HD10 review #5
Is it me or does this unit look like a rebadged Polaris?
Matt
Matt, We're not into looks, but all these utility/work type machines look 95% the same to me.
2016 Defender HD10 at work
Here are some "work" photo's I should have added to this review.
More photos. Some hard doors, windshield, cab heater and other missing parts I'm told are here. The last photo is when we tried to move a skid shed with it.... It was a bit to much for her. :confused2:
can-am 2016 Defender HD10 review with photos
This week the remaining cab parts were finally installed on the Defender. That is hard doors, with power windows no less. Glass windshield and heater. The dash photo is showing the defroster vents. The door mount rear-view mirrors were added just after these photos were taken. Man-oh-man we sure needed them
/ can-am 2016 Defender HD10 review #10
Nice set up. Looks like it well work out well for you.
/ can-am 2016 Defender HD10 review #11
Interesting. After hearing how you work equipment it made me think the Kubota might be a better choice as it is more of a commercial duty machine.
Or not. I few years back a few trail systems we trying them with the idea "these are real work machines" and they failed at this work miserably. In a separate thread I mention these failures and was not treated warmly by the Kubo owners.......
Many moons ago I resided not far from you in a little RR town of Edegmont SD.
Coming up at the end of work season here and I've written a "year 2" review of this machine. I'll post it if anyone is interested.
Hydrostatic transmission's rob to much HP and speed, so they don't work with pods that run at about 70% there of original speed. They also require much HP to push through snow and again, hydrostatic transmission's lose to much HP in there general operation.. Where as CVT transmissions have done well and only loose about 2% power. A few years ago we knew several area's running RTV's and they all gave them up, within 2 years. Nonetheless, Kudota's have not failed well in the snow or grooming business and I'll not mention the other failures operators seen with them. Our HD10 is now more than 1/2 way through its life expectancy with us, so we are pondering its replacement. What might that be??
/ can-am 2016 Defender HD10 review #15
I rarely see any Kubotas used at work sites, it's typically either a Gator or a Polaris on the work sites around here. The Kubotas are used on farms by some but even then I see more Gator/Polaris machines. The prices on Kubotas and finance options are appealing but they don't perform as well when it's true off road working.:2cents:
JD Gators do have a good reputation in our industry but all the ones I test drove, I thought were under-powered. (we receive more snow than most users) Since we do have a good JD dealer here, at this time, our the next machine will either be a Gator or another Defender.
/ can-am 2016 Defender HD10 review #17
Have you looked into the Polaris Brutus? It can be had with a diesel which I imagine being torquey would be prime for running with tracks pulling a load in the snow at slow speeds.
Blstr, We've had poor luck with Pol products so it will take some time before we get over that. Nonetheless, they've increased there engine size and if other snow grooming users have good luck with the latest versions, we'll then consider one.
We've broke to many parts on this machine, so its not likely we'll get another BPR (Can-am) for our next UTV. Oh well. No idea what we'll get at this time.
/ can-am 2016 Defender HD10 review #20
What about the JD 835R? 54hp and factory cab. Maybe the 865R diesel, or is the 23 hp diesel too whimpy for your purposes?
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2007 FREIGHTLINER...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
(INOP) JOHN DEERE 544 AA WHEEL LOADER (A60430)
(INOP) JOHN DEERE...
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
