landscape timber steps
   / landscape timber steps
I have a total rise of 5'3" from grade to the bottom of my concrete steps at the entrance of my house. The run can be anything less than about 25'/ I'm thinking maybe something like granite stone or prefabed concrete slabs 3' wide. I do have an old backhoe that can help. I ruled out landscape timbers, my first choice, due to the negative responses here. I didn't know they'd rot out.
   / landscape timber steps #12
I built a set of steps to run from a patio outside of my walkout basement, wrapping around a deck up to the first floor level. It turned out quite nice and was still nice 20 years later. I sold the place so I don't have pictures.
You start a the bottom, creating a C shape squared off of course. The legs go back into the grade further than the exposed step area. The place the next on those legs, dig into the grade for the next leg and keep going.
I made each run about 18 inches as I recall. I used long landscape nails, probably 10 inches by 3/8" . You can predrilled to make it easier.
Then compacted the area inside the step added sand and filled it in with the same patio stones I used for the patio.
You can vary the angle of the stairs runs to approximate a curve.
Oh yah, this was from treated 6x6 so each step was 5.5 inch rise so it made it a comfortable stairway.
It was beautiful and functional, but was a fair amount of hand digging.
   / landscape timber steps #13
For comfortable steps the rule of thumb is the width of one tread and height of two risers should not total less than 24 or more than 25 (IIRC)...
   / landscape timber steps #14
Width? Do you mean depth?
   / landscape timber steps #16
Ok so the rule of 24 would be pretty close to what I did
Twice the rise would be 11. 24 - 11 would be 13 for the run. This was many years ago and as try and picture it, it would be 5.5 " for the start of the run. Then I think I had a couple of courses of 6" patio blocks or.maybe a 6 and a 2. Hard to remember exactly and I think part way up I made a longer run to act as a landing.
Any way for an outdoors staircase, I wouldn't want to go with the typical 7.5 rise and 10 inch run. The shorter rise and longer run is pleasing to the eye and comfortable for all ages to use.
   / landscape timber steps #17
Also, don't use "landscape timber". I used treated 6x6 s that were of the type you would use to sink in the ground for pole buildings. I don't see why they would not hold up well for the rest of your life.
   / landscape timber steps #18
Here in East TX, our soil is acidic red clay with just about every type of wood eating bug out there. Creosote soaked railroad ties will not last ten years on the ground in contact with the soil. The bugs get through the creosote and eat them out from the inside. You never even see it happening. Just all of a sudden, it collapses. The outside looks fine, but it's hollow in the inside. I've never seen them used for steps, just in landscaping and fence posts.
I believe one of the main reasons the railroad sets the ties on a bed of gravel is make sure they do not touch the dirt so they last longer. Water will drain through the rock, and bugs do not get to them from the soil.
Same thing happened to me in Oakland... the RR ties looked great and I step up on one and it crunched... the entire cavity was termite infested... the 4 outside sides look great... guess those termites only like the tender inside?
   / landscape timber steps #19
Many companies out there sell interlocking pavers and block to build retaining walls ,steps,fire pits,and allkind of masonary structures ie stairs.They glue and pin together.Probally the best looking longest lasting brick structures without much skill or tools involved for a diy.Cheapestis to build a form and pour it .I have been a carpenter for 37 years now and have replaced more wooded outside exposed structures than u can shake a rotten 6x6 at .Just replaced 7year old 6x6 with a dust pan but the plastic home dumpo lable still there:confused2::drink:
   / landscape timber steps #20
I wouldn't use RR ties but I would use treated 6x6 s.
And I had good results for years with them.
That said, I think the combination of retaining wall blocks and landscape patio paving stones would make a great stair system as well.
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2014 Nissan Rogue Select S SUV (A51694)
2014 Nissan Rogue...
