Kyoti CK35 HST hydraulic woe's from a newby
   / Kyoti CK35 HST hydraulic woe's from a newby #42
My guess is that when you graph the two curves together they intersect at two points (I don't think the relationship is linear), but I don't have my graphing calculator in front of me and don't feel like running the math the hard way. My guess is it is an absolutely ludicrous high temperature, outside actual possibilities.
   / Kyoti CK35 HST hydraulic woe's from a newby #43
It is a linear relationship. F=(9/5)C + 32
   / Kyoti CK35 HST hydraulic woe's from a newby #44
So it is, I've forgotten my algebra. Obviously two straight lines only intersect at one point. I really wish the curves I work with were all like that.
This is all of course completely irrelevant to whatever the heck the topic was. I guess that's why I'm on TBN.
   / Kyoti CK35 HST hydraulic woe's from a newby #45
-40 is too darned cold. There, we're back on track.
   / Kyoti CK35 HST hydraulic woe's from a newby #46
-40 is too cold to even think about. I pretty much shut down in -10 (or even 0)
   / Kyoti CK35 HST hydraulic woe's from a newby #47
I'm OK with 0C, not so much 0F, although we used to ski in some frigid temps up in VT. ANd I had to work no matter what the temp was.
   / Kyoti CK35 HST hydraulic woe's from a newby #48
I am amazed it even started at -40 he must have had some type of heater. My antifreeze is not even rated for that kind of cold. We get to -20 occasionally here in Maine but I am not outside running a tractor!
   / Kyoti CK35 HST hydraulic woe's from a newby #50
There are 3 pump systems in this tractor. 1-loader/3pt, 2- steering, & 3 - hst/charge pump. #1&2 share the same suction inlet line. All 3 share the same reservoir and suction filter (filter below the platform nest to right rear tire). Pumps can heat up and whine due to cavitation just as easily as constant running over relief. If there was a deadhead situation at rear remote the loader cylinders would still work until that cylinder reached max stroke. Oil from the loader cylinders dump back to tank, not back into Power-beyond, so of path of least resistance applies.
Given extreme cold temp, whine in HST, & fast heat build up in loader/steering pump, I would guess there is enough moisture in fluid to allow ice crystals to plug the suction filter so all 3 pumps are caveating. The HST pump will move, although sluggish) without charge pressure for a little time until it pumps itself out.
2025 Western Star Trucks 49X Dump Truck, VIN # 5KKHBWDR5SLVH9247 (A51572)
2025 Western Star...
20ft Shipping Container (A51573)
20ft Shipping...
2025 New/Unused Wolverine 72'' Skid Steer Ripper (A51573)
2025 New/Unused...
New/Unused Gold Mountain Container Shelter 20ft x 20ft (A51573)
New/Unused Gold...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
