Skidding Winches
   / Skidding Winches #191
LouieJr it is easy to put a hook on. You just need some cable clamps like these and I would suggest an eyelet thingy also to reduce wear at the hook eye. You can just loop the cable thru the hook or you can be fancy and make a Flemish Eye. There is a good youtube on that. The simple way works just fine with our size cable and tractor winches.
gg
   / Skidding Winches #192
Don't forget, to put those "clamps" on, the RIGHT way,
--------------------------------------> "You Never Saddle A Dead Horse!"
SR
   / Skidding Winches #193
Looks like the clamps shown in the photo are either omni- directional, or directionless depending on your point of view.
At any rate, there is no saddle for the dead horse or the live one. ;-))
   / Skidding Winches #194
Both horses have saddles with that style clamp.
Bruce
   / Skidding Winches #195
Bruce
That's right, they are good on both the dead side and the undead side. Don't recall having seen those before, what are they called, or brand name?:anyone:
   / Skidding Winches #198
   / Skidding Winches #199
Best way to cut cable is with a mig welder, it seals the end, then I just make a small loop and use two 3/8" regular 2-$3.00 cable clamps, I get the ones at the tractor place, there stronger then the ones the hardware store carry's. I'm running 5 sliders with some grease every now and then, no hook on the end, didn't like all the limbs and twigs it catches.
Sometimes for me, hooking up 5 chokers at once is like playing cats cradle, over this tree, under that tree, go between these two trees that's still standing, I dont want to scratch-em, 50 ft. of cable goes quick, good thing I have 50' more on the spool.
   / Skidding Winches #200
To cut wire rope, I tape both ends of the rope where I'm going to cut it and use a cable cutter...
SR
2021 CATERPILLAR 289D3 SKID STEER (A51246)
2021 CATERPILLAR...
2007 Volvo VNL Truck Tractor (A53472)
2007 Volvo VNL...
1263 (A50490)
1263 (A50490)
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
