New project 1967 Ford 5000
   / New project 1967 Ford 5000
Re: New project 1975 Ford 5000
well it's been a few weeks and been busy,
It is time to get some potatoes in the ground, all these years I have used a hoe..or is it Ho' to dig rows...that sucks so I built this "row-er" or what ever it is called
I purchased 2 row crop sweeper things from Agri supply, main purpose was to use them on my hiller etc to break up the dirt that was compacted by my tires, I thought as a went looking for ho's the other morning...that sounds bad hugh :laughing: how to do this with my tractor?
I saw them laying on the trailer and said "if I could hold them behind tractor and pull them..." out came cutoff wheels, grinder and welder
I needed an adjustable clamps so I welded this up and used pennies for a .06 gap..
here it is
it is designed to slip into my 2" rec. setup I built a few weeks ago
Bent to shape after first use
it worked great!
I bought the digger spade blade thingies from Agrisupply, great folks so far!
Next? is to finish up my hiller today, and put out some more tators...
and then move on to ROPS and a cooler rack
okay,just finished today's project minus paint and some bracing...if it works;)
working from home with no access to lathes and mills sucks, so using a grinder, hand drill and 15 year old Harbor frieght drill press...I pushed on :cool2:
Spent an hour making $2.00 pins :confused2:
laid out
found some old rollcage tubing and used it for spacers
had to make a couple plates to attach discs to tubing
welded up disc holders
mounted
I can swap sides and get them 6" frpm each other
well, going to grab lunch and see if they work, I have 3 more rows of tators to put out....
okay what a day...built this last night
used it to do this
, this morning I built this:
and used it for this :
of course I did it wrong papaw said 6" of dirt on top was too much...I laughed and said I have to learn:laughing:
ETA added a picture
   / New project 1967 Ford 5000 #44
Cool fabrication. As for the 2 dollar pin, sometimes it's more fun to make the cheap stuff than to stop and go buy it.
Thank you,
more fun to make it, especially when you live 1 hour from anywhere :laughing:
   / New project 1967 Ford 5000 #46
Then it's no longer a 2 dollar pin if you have to drive that far. ;-)
as long as it's not Sunday I can grab a hate chicken and and waffle fries :licking:
then it is a $20 pin :eek:
:D
:laughing:
off with the old and on with the new.....alot quieter and fumes only come from one area :laughing:
pitman arms rubbing on exhaust is badddmmmm....mkay?
and a couple other holes
as for finished pictures?? :anyone:
imagine the "new" exhaust you installed on your 72 Nova, senior year...1 pc of flex pipe, a turbo muffler and maybe a 90* pc of tubing...same thing :D
This was middle of summer
So it has been awhile since an update
Last weekend was a long weekend
New toy...farming is like jewelry shopping
This is a 5 foot, she's rough but she has good bones
unloading
dug up yard, 2wd tractors with no ballast on the back make 4 inch deep trenches fast :D
so I pulled truck out from under it
FRIDAY:
needed to clean up one of the fenced off areas
a **** ton of passes to go
ohh F%^#@$
I found my plow...thought tractor was going to roll over as front tires drove over the 18" boards
I forgot where I left it
decided to grab weed eater and "find" the log splitter for rebuild
set up on stands
SATURDAY:
Does my butt look fat?
new toy
prepped area earlier this week
LOOK...could be worth more than gold in the future
2 rows dug.......8 buckets...7 more rows to go!
going down to weed eat some more rows of potatoes...c-ya'll
Hope to get more tators out this weekend
Next projects for the winter will be ROP system (have material just no time)
a couple of bush hogs to build and maybe have a rebuild on a small tractor for the wife
next year we will put out a couple acres of potatoes and watermelons and pumpkins:laughing:
2025 New/Unused Wolverine Skid Steer Land Leveler (A51573)
2025 New/Unused...
2009 Volkswagen Jetta Sedan (A51694)
2009 Volkswagen...
John Deere 1018 10ft Rotary Cutter (A51573)
John Deere 1018...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
2009 KENWORTH T6 SERIES SLEEPER (A52576)
2009 KENWORTH T6...
