Lead shot to add weight to implements?
   / Lead shot to add weight to implements? #31
Water sloshing back and forth can be a real problem on a slope.
   / Lead shot to add weight to implements? #32
Easily solved by having a sealed or at least closed container & filling it all the way before closing it. It cant sloh if there is no empty space to slosh into.
   / Lead shot to add weight to implements? #33
I did not read all the posts mostly because I think this is not a good idea. First of all, lead and the dust from the vibrating pellets is vey toxic and easily breathed in while handling or maybe even while using. This is proven science. Second, someone will someday cut or weld that area and have the same lead problems by years of vibration. A wild guess as well is wondering if the dust from lead can be explosive if a spark is introduced into a closed area. I don't think so but many other dusts are.
You can also use round barbell weights as an easy fix for many things. I made a bracket with a round post welded on and then just slipped on the weights needed. Works great. I don't care for the lead idea.
2013 WILCO MACHINE & FAB INC. WILCO MACHINE & FAB INC. (A50854)
2013 WILCO MACHINE...
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
2018 East Texas 20ft Utility Trailer (A49461)
2018 East Texas...
2018 AFE SSMM Disc Mulcher Skid Steer Attachment (A49461)
2018 AFE SSMM Disc...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
