Lead shot to add weight to implements?
   / Lead shot to add weight to implements? #31
Water sloshing back and forth can be a real problem on a slope.
   / Lead shot to add weight to implements? #32
Easily solved by having a sealed or at least closed container & filling it all the way before closing it. It cant sloh if there is no empty space to slosh into.
   / Lead shot to add weight to implements? #33
I did not read all the posts mostly because I think this is not a good idea. First of all, lead and the dust from the vibrating pellets is vey toxic and easily breathed in while handling or maybe even while using. This is proven science. Second, someone will someday cut or weld that area and have the same lead problems by years of vibration. A wild guess as well is wondering if the dust from lead can be explosive if a spark is introduced into a closed area. I don't think so but many other dusts are.
You can also use round barbell weights as an easy fix for many things. I made a bracket with a round post welded on and then just slipped on the weights needed. Works great. I don't care for the lead idea.
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
2013 Jeep Patriot (A50324)
2013 Jeep Patriot...
2010 International 4400 National Crane 300C Crane Truck (A50323)
2010 International...
2014 FORD F-350 SUPER DUTY CREW CAB FLATBED TRUCK (A51243)
2014 FORD F-350...
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
