rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 11,402
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
We have a Kubota B2910 which has a single adjustable, ratcheting side link.
This thing has broken on me twice now ... largely because Kubota chose to make one of the component parts out of inferior cast metal.
Unfortunately, Kubota does not offer the single part that breaks as a separate item for purchase ... you must buy the entire barrel ... which is rather pricey (around $70 IIRC)
And of course it comes with another piece of cheap cast metal on the part that is prone to failure.
So I'm looking for someone who can do a one-off out of mild steel.
Should be fairly easy I would think for some who has the proper equipment (a mill)
I can supply the pieces of one of the broken ones for reference.
The part is the lower case for the ratcheting mechanism in the following image and is marked (called out) with an "A" (on the left side, just above the "A" in a circle which refers to a different part)
Any takers ?
