Front bucket hooks gc series
   / Front bucket hooks gc series #1
Bevis
Indiana
None yet
I have a gc 1710. There was some plugs on the front end loader I replaces with some hooks ( see photos). What has everyone put there? I put some removal eye hooks that are often used for trailers I got a rural king. They unscrew when not in use. Anyone see a problem with these? I have yet to use them.
   / Front bucket hooks gc series #2
Hu, i never noticed the plug or hole before. I will have to investigte tomorrow.
   / Front bucket hooks gc series #3
I got some weld-on hooks (also from a trailer place) and welded them onto the top edge. Very handy.
   / Front bucket hooks gc series #4
Good idea, hopefully they won't distort the rear wall of the bucket when used to lift something heavy, that's a lot of stress concentrated in a small area.
   / Front bucket hooks gc series #5
I can see why people weld on the 2inch receiver, but what do y'all do with your hooks? I have pallet forks for lifting.
I like the idea of hooks, just not sure what I could use them for.
   / Front bucket hooks gc series #7
Just curious . . if you had a hook at each upper corner of the bucket a person could weld a small support block to the underside of the top edge and to the side wall to give added strength to the corners. Has anyone done it ?
   / Front bucket hooks gc series #8
If you are really worried about stressing the bucket lip when welding on chain hooks, just make a reinforcing pad to put on the FEL bucket then attach the hooks to the pad. I didn't have any scrap of sufficient thickness when I put hooks on my LS, so I found some brackets made for attaching springs to trailer axles. They were 4"x6"x3/8" thick. I welded them all around onto my top lip of the FEL, then welded the chain hooks to the pad. I have used these with a chain to lift the front end of my 1/2 ton Chevy truck off the ground and no movement of the hooks.
For these small CUT's which may be capable of lifting 800# at most, you wouldn't need that thickness of pad but the size should still be similar so any weight would be spread over a larger area. I would think at most a 3/16" thick 4x4 or 4x6 (whichever fits the top best) should work well.
   / Front bucket hooks gc series #9
Yes, and this is why we sell laser cut plates for those that want to use them.
   / Front bucket hooks gc series #10
Kennyd's photo at the bottom of post #6 illustrates it well. In a word Chain. Almost anything that you are trying to pick up that won't stay in the bucket calls for a chain and then where do you hook it ? Those hooks welded to the top of the bucket. I would estimate that 80% of the tractors larger than 25 hp that I have seen in recent years have hooks welded to the top of the loader bucket. "everyone" does it.
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
2014 Ford F-150 Ext. Cab Pickup Truck (A52377)
2014 Ford F-150...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53473)
GOODYEAR SET OF...
