1533 50 hour service cost
   / 1533 50 hour service cost #41
swap the filter at 50 hours when you do your engine service... then schedule a full service from there each year unless your putting over 200 hours a year on I t
I go about 1000 hrs on hydraulic oil and change filters every 500 hours on my Kubota. I use royal purple oil
Only moisture collecting in the oil would reqire a change sooner.
I just did a 100 hour service on my Max28 and its going to be good for several hundred hours. No metal in filter.
   / 1533 50 hour service cost #42
well it wont pull up on mine now and its been a while since I seen this thread.. please let me know what it is your looking for which I think was fuel filter and ill pm the part number to you
I found the numbers elsewhere on the forum. This forum has been a great help in learning about my tractor. Thanks to all from a newbie owner. And I agree, the Mighty Mahindra is a powerful little tractor that should give years of dependable service.
   / 1533 50 hour service cost #43
I use a premium universal fluid also.. but being in the lowland area im in were central Tx meets East Tx I get a lot of moisture build up and don't chance it past a years time.. in dryer areas hydraulics can last a loooooonnnnng time without service... I still wouldn't go 1,000 hours though in any tractor. Not saying its wrong or right,... no reason to fix something that aint broke
2003 Ford E-350 16ft Box Truck (A50323)
2003 Ford E-350...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2025 12V Diesel Pump, Nozzle and Hose with Meter (A50323)
2025 12V Diesel...
7' x 7' Steel Frame Cover Hut (A50121)
7' x 7' Steel...
2019 Cub Cadet ZT1 54in Zero Turn Commercial Mower (A50322)
2019 Cub Cadet ZT1...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52748)
2023 New Holland...
