Windows 10
   / Windows 10 #31
ran across this on an other site, Ultimate Outsider - Software Downloads GWX control panel,
it is a program that deletes and stops the windows 10 popup and the other stuff they sneek in during updates for windows 10, I put it on one machine and could see no ill effects, and I have it now on three machines, and no more popup and icons,
what others say about GWX GWX control panel - Google Search
I had manually deleted the one up date at one time, but was a hassle to manually update, when I saw this I thought it was worth a try, it came with high recommendations from the other site I saw it on,
   / Windows 10 #32
If you make it available offline, you can add a network folder to a library (this is true from Win7 on up).
Aaron Z
   / Windows 10 #33
it is a program that deletes and stops the windows 10 popup and the other stuff they seek in during updates for windows 10, I put i on one machine and could see no ill effects, and I have it now on three machines, and no more popup and icons,
I can recommend that. I have used it on all our computers here and some of the ones at work.
Aaron Z
   / Windows 10 #34
I'm about to rebuild my Win7 laptop and may upgrade to Win10 to see how I like it.
I'm thinking about a dual boot system, Windows for when I remote into work and Ubuntu for personal stuff. I'll get freeware Libre Office either way and not pay for the licensing of MS Office.
I can't get my wifi to work consistently in Ubuntu or I'd already be switched over. Going to try a cat5 cable to see if that works and if so I'll be up in the attic fishing wires.
   / Windows 10 #35
I upgraded about 6 months ago with no issues. My new laptop came with it and again no issues. I teach computer apps, security, IT, networking, etc... at the local community college and have some experience with these systems. Overall 10 has been stable. The automatic updates can be addressed. Microsoft wants to go to subscription services as do most all software companies. They need the revenue stream. Ubuntu and Linux are alternatives but programs and market share are still small. Eventually Microsoft requires software upgrades by not supporting older operating systems. That I do not like. Very few alternatives if you want to stay mainstream.
   / Windows 10 #36
I have no problems with Win 10. Upgraded 2 laptops at home. My old Vista machine is now obsolete but it's a desktop and probably needs replaced anyway. It has been a great machine.
   / Windows 10 #37
I did the upgrade from Win8.1 months ago. Only major issue was how they manage updates which seems to have been a major complaint amongst us "metered" service people. Near as I can tell you can control the "install" but not the "download" (former being a "nothing" in terms of the monthly allowance, the latter chewed up 4gb in a couple of hours when I wasn't paying attention). I think MS got the message on that because it hasn't happened recently...in the meantime HughesNet is now back to granting "restore tokens" on their Gen4 plans...they are aware of the issues also. Don't think I ever had a Win 7 machine (one is still running XP merely for data storage, another one runs Vista). One thing I miss is the old "Outlook Express" e-mail. Was missing in Win8 and is still missing in Win10. Guess they want you to spend the money for Outlook. I run MS Office 2013 and it works just fine. Quicken 2013 and later run fine. MS Money "sunset" works just fine. Even my old Adobe Acrobat (ver 9 I think) works fine.
   / Windows 10 #38
Had a very old notebook running XP......I bit the bullet last year and bought a new laptop with a Core I3 processor and Windows 10. What a difference. Fast and easy to use. Took only a short time to get used to both.......didn't realize how bad my old notebook was. I like 10!
   / Windows 10 #39
I bought a new computer with W10. I can't stand it. There's no doubt in my mind it was solely designed by MS to optimize ads and data collection. It's the most unstable and least user intuitive of all the Windows versions I've used.
I'd avoid it if you can.
   / Windows 10 #40
I asked an IT friend about W10 and his reply was Ubuntu Linux....it will be used on my next laptop.
Unless you are a Unix guru you should put it on your present laptop, in a separate dual boot partition and learn it's use slowly.
Try getting a USB wi-fi dongle, KNOWN TO BE Ubuntu compatible. Ubuntu apparently does not play well with the chip (Broadcomm?) at the base of most Wi-Fi implementations. The compatible ones are not very expensive.
I'm running 8.1 on this pc and I haven't had any problems with it, other than finding it difficult to do disk maintenance as I'm used to, the chkdsk and scandisk type functions. Maybe it's all automatic now.
It sounds like the majority of experiences noted here have been positive.
Unless there is some highly improved functionality, an actual benefit to upgrading,
I remain unmotivated to do so.
My computer issues aren't with Windows, they are with Firefox crashing when videos are turned off midstream.
But still much better than IE; and what a challenge getting IE out of areas where it had burrowed, designed to pop up later
and retake lost ground.
If it works don't fix it. But try running a dual boot with some flavor of Linux maybe off an SD card or flash drive. The when Windows 11 comes along for $100/year you can tell them to stick it.
I didn't get "started" in computers until about 1970 at IBM Burlington. I was there to help cut the first chips that they put THREE transistors on! (I worked stacking the heads that cut the silicon wafers).
I started working with Unix about 1980. I didn't get to start Linux until about 1992 w/ version 0.95 with X. I think it took about 12 floppies. Since then and up to when I retired I always had at least one machine running some version of Linux.
Now I've been reading the Microsux may be moving Windows to a subscription based OS. I'll be moving back to Linux.
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
2022 CATERPILLAR 980 WHEEL LOADER (A52705)
2022 CATERPILLAR...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
