Gannon Box Blade 6 ft on CL
   / Gannon Box Blade 6 ft on CL #31
My problem with qh compatibility is shown below i'm pretty sure i could turn the cylinder around if the ears were located down a few more inches. Mine is a new model though
heres the link to the post that i sent to Gannon to have QH compatibility removed from their site
http://www.tractorbynet.com/forums/attachments/304549-gannon-88-hsd-box-scraper-post3710424.html#post3710424
Well, it took m longer to get around to adding pix.
It was pretty large for my little tow dolly, but I managed.
   / Gannon Box Blade 6 ft on CL #33
Nice!! Looks bigger than 6'?
Now let's see some pics with rippers down and box full!
It's 73" outside edge to outside edge, with 1/2" plate steel for the sides, makes it 72" inside dimension.
I can't really use it yet, need real pins.
   / Gannon Box Blade 6 ft on CL #35
Nice! How many remotes do u have? Hydraulic top link a must IMO.... With hyd sidelink is the cats meow..
   / Gannon Box Blade 6 ft on CL #36
Nice, looks to be hardly used.
Thanks, I have one rear remote already plumbed & set up, w/ space for 2 more.
Would like to get a top-N-Tilt, but i got to figure out how to install.
Does it matter which hose goes where? How do I know which side is the power side and which is the return side?
   / Gannon Box Blade 6 ft on CL #38
They are both pressure. You can switch if you don't like the way the handles operate.
   / Gannon Box Blade 6 ft on CL #39
Go to TYM and get your 2nd & 3rd set of rear remotes. Shouldn't be all that hard to install. Actual top & tilt set runs $870 + shipping costs.
Nice find with the Gannon, it will serve you well. :thumbsup:
   / Gannon Box Blade 6 ft on CL #40
Nope, doesn't matter... Only difference is which direction the cylinder moves when u push or pull the valve lever.
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A53421)
2018 John Deere...
2016 Genie S-45 4x4 45FT Telescoping Boom Lift (A53421)
2016 Genie S-45...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
2017 Nissan Versa SV Sedan (A53424)
2017 Nissan Versa...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
