Gannon Box Blade 6 ft on CL
   / Gannon Box Blade 6 ft on CL #41
Totally matters to me. If, for some reason, I get em backwards, immediately switch. :)
Well I hooked it up right first time. When I push lever FWD it comes up. Only thing is I then have to move lever back to neutral position or it begins squealing. I wish it was spring loaded to the center detent.
And when I pull lever BACK it gos down, & then locks.
No leaks either that I can see.
BTW, where can I get hydraulic hose covers, as the sun is pretty intense here in the High SW, & protective covers would be nice.
Looked on ebay under hydraulic hose covers & did not see anything.
   / Gannon Box Blade 6 ft on CL #43
Squeeling = deadheading. Means you'll generate heat quickly... Try not to ;)
Are you talking about the end connectors (tractor supply)? Or some form of hose cover?
   / Gannon Box Blade 6 ft on CL #44
How much do you want? $2 per ft plus shipping costs. This size just fits over the male coupler end to give you an idea of it's over all size.
   / Gannon Box Blade 6 ft on CL #45
Congrats on the new beast. That one looks just like mine except it's in much better condition. You got a great deal on it.
2018 PETERBILT 579 DAY CAB (A51222)
2018 PETERBILT 579...
Blue Concrete Test Shed (A49461)
Blue Concrete Test...
1273 (A50490)
1273 (A50490)
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
Pallet Fees (A50775)
