Mowing BX mowing deck "gear box" oil change
   / BX mowing deck "gear box" oil change #21
Gotcha... I misread your post. PHILIP8N's application specifies SUDT-2 for the mower gear box, which surprised me. Can you use it? Probably. Should you? I would stick with what is specified in the manual.
   / BX mowing deck "gear box" oil change #22
From my manual. Philip.
   / BX mowing deck "gear box" oil change #23
I have a BX, I see in my manual for the BX I can use SUDT2 in transition (hydraulics) and front axel, but my mower manual does not, is it because Kubota was to lazy to change the manual or ??
Philip, I see you have a 2009? so have you been using it in your mower since then? When did you do your first change on it?
On a side note: not that I want to go off topic of this thread, is any of the engine oil Kubota supplies synthetic or semi ?
   / BX mowing deck "gear box" oil change #24
Trying to be helpful here........my OE manual (2009) for the BX mowers RCK60B, 54 and 48 say to use "SAE 90 API GL5 Gear Oil". I'm sort of surprised that Phillip8N's manual says otherwise. The Kubota dealer said that their 80-90 gear oil was just as good. Go figure.
My thinking is that the mower gear box is turning a whole lot faster than the front axle gears that use UDT varieties....Thus, I'd use a 80-90 weight, if it were me.
   / BX mowing deck "gear box" oil change #25
Hi,
This is why I am bringing up this subject, to find out what others feel and think.
My manuals say the same, but SUDT2 can be used in transition (hydraulics) and front axel, isn't the hydraulics more moving than the gears in the mower great box?
Also since more car manufactures are also switching to synthetic, either being tighter tolerances or? Wouldn't synthetic in the mower gear box be better also?
Thanks to all!!
   / BX mowing deck "gear box" oil change #26
My GR2120 is a 2013, which has very similar mower deck as your BX, same gearbox.
I changed my engine oil at 11 hours, then again at 50 hours. I changed the mower gearbox oil after the 1st summer of use.
Kubota USA factory fill engine oil is mineral 10w-30.
My Grand L3940 is a 2009.
Philip
   / BX mowing deck "gear box" oil change #27
Philip
Thank You Philip.
I am going to use the Kubota SUDT-2 also as you do for the gearbox and transition (hydraulics) and front axel.
Just one more question please, do you use the Kubota oil for the engine or what brand and w?
Thank you
   / BX mowing deck "gear box" oil change #28
Thank You Philip.
Thank you
I do not use Kubota brand oil for the engine. I use a name brand 5w-40 synthetic oil. Philip.
   / BX mowing deck "gear box" oil change #29
Interesting reading this 1464576049224.jpg my zd1211 gear box calls for 10w30 engine oil but the rear discharge calls for 90w. Some call for SUDT very interesting
   / BX mowing deck "gear box" oil change #30
I didn't know you were supposed to change the gearbox oil. I have gearboxes with a couple of thousand hours on the them.
2025 K1119 UNUSED Metal Carport (A53117)
2025 K1119 UNUSED...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2015 CHEVROLET C3500 SERVICE TRUCK (A51406)
2015 CHEVROLET...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
