Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #3,401
Now, what do I do with it? I have cleaned up everything except the trunk of a large cottonwood. I burned everything so far - with some difficulty! Had to cut into pieces small enough to move. It's giving my chainsaw and little tractor a workout. There is still about 25' yet to move. Lots of ants too.
   / Tractors and wood! Show your pics #3,402
NOT a problem at all, Jim...
SR
Are you washing the logs to clean them up before milling?
I have no experience with skidding or milling and always wondered how often skidding would pick up rocks to cause a problem milling.
   / Tractors and wood! Show your pics #3,403
Some times there's no way to get the logs out, with out getting them pretty dirty, so they get a good wash,
Anyway, then they go to the BSM and are sawn into what ever I need,
SR
   / Tractors and wood! Show your pics #3,404
My FIL made a log-lift for the 3PH on his bigger tractor so we can take trees out of the woods without getting them muddy.
   / Tractors and wood! Show your pics #3,405
SR
Thanks for the explanation... I learn something every visit at TBN
On a separate note... I will be doing some cutting in the woods and all will be fine and then it won't cut... never fails... some old barbed wire, nail/spike... even square nails.
It sure doesn't take much to dull a chain and quick... like a rock that somehow the tree grew around.
   / Tractors and wood! Show your pics #3,406
SR
Thanks for the explanation... I learn something every visit at TBN... almost looks like a small firehose?
   / Tractors and wood! Show your pics #3,407
That works "some times", but when you are selective cutting timber out of a woods, "snaking" the logs out from between trees with a winch, you just can't get them out any other way... Many times it's not mud, it's sand and composted leaves ect...
Once you have the room, then there's a number of ways to keep logs from getting dirty, but it's just so fast/easy to wash them, I quit worrying about dirt long time ago... lol
BTW, I use a std. fire hose and nozzle, so it's the "high volume" that does the job of cleaning!
SR
   / Tractors and wood! Show your pics #3,408
SR
Rob, are those 48" forks with your grapple?
   / Tractors and wood! Show your pics #3,409
Yes, and they are the PERFECT size with the matching grapple.
When I sort "certain logs" out of a pile, like the pictured cherry,
I can hold one log with the grapple, while I dig another out of the loaded trailer. That's how I sort my logs as I unload them, that way they go on the right pile, to be milled later.
Another really great thing about this combo is, I can hold one log back with the grapple until I'm ready for it, as I roll the front log onto my sawmills deck. It keeps the logs cleaner and every thing goes faster, with less trips to the log pile.
It never ceases to amaze me how useful this combo is!
SR
   / Tractors and wood! Show your pics #3,410
What are proof lines?
The 3 indicator lines etched or stamped into the steel plate are there to show
you easily if the holes have been stretched. If so, the lines will no longer be
straight.
UNUSED Quick Coupler (A47477)
UNUSED Quick...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
Mini Excavator Rake (A53316)
Mini Excavator...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
2016 Club Car Carryall 1500 4x4 Utility Cart (A55787)
2016 Club Car...
