How much can a 40hp tractor tow??
   / How much can a 40hp tractor tow?? #12
Is the allowable trailer weight with and without trailer brakes listed in the Kioti literature?
Seems like I've seen such figures for tractors before, just not sure which brand(s).
Is the allowable trailer weight with and without trailer brakes listed in the Kioti literature? Seems like I've seen such figures for tractors before, just not sure which brand(s).
Haven't seen that. Will look.
   / How much can a 40hp tractor tow?? #14
How long is the grade
   / How much can a 40hp tractor tow?? #15
I would rather use a truck, but if your drawbar rated to carry 1000# it technically should be fine. Hook her up on the flat and see how the tractor handles it... if its the least bit light in the front I'd just use a truck. How much does the manufacturer rate on the drawbar, and what % of the load does your tractor weigh?
I don't own a truck that can pull 9000-10,000lbs. However, Plan B is to get a neighbor with an F250 to help.
   / How much can a 40hp tractor tow?? #18
My 1720 Ford (28hp) towed a 6500lb chipper up & down dirt roads much, much steeper than a boat ramp.
I would say no problem providing it's 4wd and the brakes work properly.
90cummins
   / How much can a 40hp tractor tow?? #19
Bobcat's version of that DK40, CT440 list tow capacity of 1433# tongue weight and 7716# total trailer weight. That is without any front ballast so with loader and bucket and using reasonable slow speed & 4WD going up down ramp I see it as doable.
   / How much can a 40hp tractor tow?? #20
I towed that and some with my 28HP Jindal but never any long grades like that.
My tractor and FEL was 5200# so weight of the tractor does make a difference.
Chris
UNUSED (2) 7000# DROP AXLES W/ BRAKES (A54756)
UNUSED (2) 7000#...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
2000 Freightliner FL70 Manitex 14 Ton Crane Truck (A55788)
2000 Freightliner...
(2) GAS HEATERS (A54756)
(2) GAS HEATERS...
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
2018 JLG 450AJ CLEARSKY MANLIFT (A52705)
2018 JLG 450AJ...
