Reccomends me an 8' twin spindle cutter
   / Reccomends me an 8' twin spindle cutter #21
Sort of related to LD's search, has anyone ever seen a 6' twin spindle cutter?
Yes, it was an ancient (probably homemade) rusty contraption. Generally, the only multi-spindle 6' mowers are finish mowers.
Edit, found one: 6 foot 3 point bush hog heavy duty
00l0l_gZWP4kjhy4Q_600x450.jpg 01616_464CtYTHASD_600x450.jpg 00D0D_2o8MDqPmoPt_600x450.jpg
Aaron Z
   / Reccomends me an 8' twin spindle cutter #22
I've been running a JD 709 7 footer behind a Ford 4630, tall, thick vegetation is not its strong point. It's heavy duty and destroys brush, small woody material up to 4". I just ordered a Woods MDS 96 8 foot dual spindle 3 PT mounted cutter. I'm hoping it does better in the field.
That's just what I want, but big $$$$. Let me know how you like it
I have seen a few big 8' singles.
I wouldn't be opposed to one of them if it isn't too heavy. But I think that's the problem. Weight +length would require leaving the FEL on, which is what I want to get away from. A 1500-2000# 8' twin,with it's shorter length should allow me to drop the fel with the mx5100
   / Reccomends me an 8' twin spindle cutter #26
Have you looked at a Howse?
The 10' list a blade speed of 13.6k. The 8' is not on website but dealers around here are advertising one. I have no experience with them but I do see a few around.
   / Reccomends me an 8' twin spindle cutter #27
Could you get by with a pull type? Just wondering. I've got a nice Brown 472 six footer. I would like to run an 8 or 10 footer. I've got an older Howse 10 footer that needs a right gearbox replaced. I just have not had time to repair it yet. That is probably what I should do but the darn thing weighs around 1800# and like you I would need to keep the FEL on to run it. I think a pull type would be a better option.
Pull type would be okay if I was only maintaining my property, or close to me.
But this is for business. I travel all over. Sometimes up to 2 hours from home. And mow sever hundred acres a year. Trailering is the reason for not considering larger, or a pull type mower.
   / Reccomends me an 8' twin spindle cutter #29
Look to the left, under your avatar... says you still own a Kubota L3400 :)
   / Reccomends me an 8' twin spindle cutter #30
I went from a 6 foot to a dual 8 hardee cutter, such a big difference. It only has a blade speed around 13,700 but does a nice job of finish cutting , but I keep good blades on it and don't use it for very rough cutting. It weighs 1600 and even on real steep inclines like my dam, it doesn't make the front to lite, but you can tell its on there, however I do run with the loader on but no bucket or anything. Only real complaint I have is that it windrows the cuttings a lot since the spindles counter rotate.
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
2017 VOLVO VNM DAY CAB (A51222)
2017 VOLVO VNM DAY...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2021 POLARIS RANGER 4x4 UTV (A51222)
2021 POLARIS...
2017 RAM PROMASTER 2500 CARGO VAN (A51222)
2017 RAM PROMASTER...
