Advice on potential purchase (Nortrack 3500B)
   / Advice on potential purchase (Nortrack 3500B) #61
Hahaha. No, I don't know what you mean. People have put gasoline, kerosene, and all sorts of wrong stuff in their fuel tanks. Some people even refer to a diesel key switch as an ignition switch. Kinda makes me wonder some time. I am **** about some things.
LOL hahahaha
Changed the fuses and bled the fuel system. Fired right up.
   / Advice on potential purchase (Nortrack 3500B) #63
LOL hahahaha
Probably all you needed to do was bleed the fuel system, and the only time you really need to do that is when you change the fuel filter or (GASP! :embarrassed:) run out of fuel.
On that note,
Where do you get your fuel filters for the dozer?
Do you happen to have the proper part # from a supplier like Napa, ect?
   / Advice on potential purchase (Nortrack 3500B) #65
Probably all you needed to do was bleed the fuel system, and the only time you really need to do that is when you change the fuel filter or (GASP! :embarrassed:) run out of gas.
Fixed it for you:laughing:
   / Advice on potential purchase (Nortrack 3500B) #66
On that note,
I get my filters from NAPA, unfortunately I don't have the numbers with me but I can tell you when I get back to the shop. For the engine oil filter you will have to determine whether you have the metric or SAE filter head - the OEM filters are different but have the same part number. The TY395 engines came with both types.
That would be great if you could post the part number for the proper NAPA fuel filter. I have already covered finding the oil filter.
Thank you so much Bob.
I need to make you dinner sometime. Truly.
I found this information?
NAPA FIL3195 (gold)
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
(5) 55 GALLON POLY DRUMS (A51248)
(5) 55 GALLON POLY...
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
0375 (A51694)
0375 (A51694)
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
