Based on this and the "grapple width" thread, I decided to get the 60" grapple. I saw no advanatge to a 72" but lots of people had good things to say about the 60".
Plans went awry when I got the place and found out that the last two 60" had just sold and were being loaded as I got there. So the alternatives were either the 66" or the 72". All three had the same exact price: $995 even though the weights were 600, 550 and 500 lbs respectively, go figure.
And then I mentioned that I had lots of rocks at my place. They then showed me their 48" brush grapple with the tines much closer together that could be used for rocks. It was also cheaper at $795. That, and not paying tax due to the TN farm exemption, I saved almost $300.
After watching Ted's EA video on 3rd functions kits, I decided to order the 3rd function kit from National Implements in Idaho:
Construction Attachments Dedicated Third Function Hydraulic Valve Kit, Less Hoses, Up To 14 GPM I ordered it with the optional SS flat-faced couplers so that it would interface with the grappler's couplers as-is.
Since I saved almost $300 on the grappler, I decided to see if the farm store could also add 3 remotes to the rear of the tractor while they were doing the rest of the work. No problem they said.
So now I'm ordering this valve from Surplus Center:
3 SPOOL 8 GPM PRINCE MB31BBB5C1 DA VALVE Is this the correct valve for remote rears and uses such as TNT etc. etc. etc.
J-J I'm looking to you for your opinion here!
Some pics:
Grapple:
3rd function kit from National Implement:
Thanks for all the help, I appreciate it!
