Thoughts on this grapple from a local dealer?
   / Thoughts on this grapple from a local dealer? #51
Yes, the valve I listed will work. Its 10GPM. And not too big physically that makes it difficult to fit.
Monoblocks take up less room than a stack type, and fewer places for potential leaks. The downside is, if you have one spool start to leak, you cannot replace just a single spool. But a single spool section for a stack type is ~$100+, and a whole new monoblock valve is ~$200.....I'll stick with a monoblock up fromt.
Also keep in mind that load holding is a function of the quality of the valve. No valve is perfect, but the leakdown rate is better the more money you spend. With my toplink on and my heavy DS96 cutter mounted, The cylinder will drift down at about 1/2" per hour. Which is acceptable by my standards.
As much as I would have liked to have at least two float spools, for both toplink and sidelink, it just wasnt worth doubling the cost of the valve to get it. And I cannot think of one instance where I would want BOTH the top and sidelink cylinders in float at the same time. So for me, when I need side link float, its just a matter of swapping the hoses.
I also added flow controls on all the remotes. They are expensive but I already had them on the shelf. (I get a lot of surplus stuff like this from time to time at auctions, or when the companies I have worked for in the past clear out the stock room of unused parts, or stuff I have bought for other projects and never used, etc). So I can close them off and not have to worry about leakdown through the valve. Similar to how the DPCV TNT cylinders work, but still with the option of float.
Lastly, the mounting bracket I made. I couldnt find anything I liked online to clamp mount the couplers. Are you familiar with two-way sleeve couplers?
Alot of people just mount via the fittings which always require two hands to couple/uncouple. If you are okay with that and dont want breakaway protection, there are easier ways to mount them. But that bracket wasnt hard to do. $40 buys a foot long piece of aluminum, 1" thick and 5" wide. Then all you need is a 1-1/2" drill bit to drill the 6 holes. A 1/2" drill bit to drill the mounting/clamp holes. And a bandsaw to slice them apart.
Most of those couplers also have snapring grooves to "bulkhead" mount them by the sleeve as well. But wasnt sure how rigid that would be trying to couple and uncouple.
   / Thoughts on this grapple from a local dealer? #52
I like the way you get things done LD1. If you cannot find a suitable coupler mounting block.. Just build one. :thumbsup:
   / Thoughts on this grapple from a local dealer? #53
I build alot of things if I cannot find what I like. Having a mill and lathe, or access to them is priceless
   / Thoughts on this grapple from a local dealer? #54
LD1 you make me "green with envy" at your access to those machines and the ability to use them...
Makes it hard on us wannabee machinists...
Around here on the farm all we ever used was an old Smith stick welder to repair broken machinery...
Got by as best we could...
Welder still works...
   / Thoughts on this grapple from a local dealer? #55
Having a welder and knowing how to use it is half the DIY battle right there. You can make alot of things, or save yourself some costly repairs with one.
   / Thoughts on this grapple from a local dealer? #56
Couple years ago I added a 180 Amp MiG Welder. Pop had one of those cheap Buffalo 4x6 metal band saws. It was a 1983 model made in Taiwan with a 3/4 horse motor. Thing still works. With that and my floor drill press I am a dangerous man.
[snip]
[snip]
:laughing::laughing::laughing::laughing::laughing::laughing::laughing::laughing:
Wait! Was that a serious question????
[snip]
I knew that as soon as I posted that picture, you were gonna go there. You did!!!
CS: "To make an apple pie from scratch, you must first invent the universe."
I wanna get a little further along than baking the apple pie from scratch process. More sorta like the Amazon/FitRite/Ken's Bolt On Hooks-type baking the apple the pie.
ETA: No Offense.
   / Thoughts on this grapple from a local dealer? #59
Yes it was a serious question. Most people just think a coupling is a coupling. I'd say the vast majority of what is used and sold for ag stuff is single-way sleeve. Still gets breakaway and the handed unhook if clamp mounted. Only thing you lose is one handed hookup.
I don't know you from Adam. So yes it was a serious question.
   / Thoughts on this grapple from a local dealer? #60
I would be willing to bet many on here don't understand what you mean by "breakaway" and "one handed coupling". To be honest with you I didn't either until a few years ago when I got serious about understanding how the couplers worked and the differences in them. When I got my first 2 way air coupler I was in "hog heaven" and wondered why in heck I didn't get these sooner.:) A picture, or in this case a video would be worth a thousand post's. :)
2012 Chevrolet Express 3500 Passenger Van (A55973)
2012 Chevrolet...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
2020 DRAGON ESP...
Informational Lot - Financing (A56435)
Informational Lot...
MASSEY FERGUSON 275 TRACTOR (A58375)
MASSEY FERGUSON...
2025 GPS Utility Trailer (A56859)
2025 GPS Utility...
