How would you straighten this?
   / How would you straighten this? #22
Buy a new piece of pipe for $5 and weld the foot on.
   / How would you straighten this? #24
Buy a new piece of pipe at Home Depot, they will thread it for free. Screw on a wall flange and throw the other junk away.
   / How would you straighten this? #25
I think I'd try to find a piece of tube that fits inside and try to pull it back straight. If the piece inside pushed against the slight kink might push it out. Problem will be anchoring the tube close to the bend so it straightens the curve and doesn't create another bend. It's already bent so you have nothing to lose. A "little" heat on the opposite side of the kink wouldn't hurt as that side needs to compress to straighten.
   / How would you straighten this? #26
Actually my first thought was if you could force something like a (window) sash weight...down through the pipe with a press or hyd. cyl etc...it would be effective...The only issue of heating it would be a slight weakening IMO...
   / How would you straighten this? #28
getting the kink out would be the hard part. sA has the right ideal using heat. I would heat thin red lines around the outside of the bend and then spray with cold water. trying to heat the entire bent area and cooling in one pass wont work as well has heating several thin red lines and cooling. I bet you will spend more on gas heating the metal than it would cost to just replace it with new material.
   / How would you straighten this? #29
I wouldn't trust it if you straightened it. In my experience, it will be weaker then before. I would expect it to fail on you.
I would either through it away and buy a new one, or use the ends of it on a brand new pipe that is of a thicker gauge. Regardless of why it bent, I always want to replace something that failed with something stronger.
   / How would you straighten this? #30
Has no one thought about just putting it back in the jack stand facing the opposite direction and then drag the trailer forward just like you did to bend it the first time. Go slow and have a flagger to stop when it gets straight. If that doesn't work, just fab up a new piece of pipe. You may not want to go stronger because the next time it may break the mounting attachment rather than just bending the foot.
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
2017 Jeep Patriot 4x4 SUV (A55853)
2017 Jeep Patriot...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A55301)
DeeZee Crossover...
2023 John Deere 9RX 640 Track Tractor (A53485)
2023 John Deere...
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
