Box blade and Rotary cutter
   / Box blade and Rotary cutter #21
Setup a search filter on Craigslist directly. It has options for search nearby locations itself now. No need for 3rd party stuff. Can set the search filters to Email as well.
I appreciate all the responses. I have decided to stock with CL in light of all the different searches. I have come across many that I did not see before. If I can find heavy duty used, I will be thrilled.
   / Box blade and Rotary cutter #23
What's your price range?
I think I'm going to sell my land pride hrl 3578 with hydraulic scarifiers. It's 78" wide and weighs 981 pounds.
Shipping could be a killer but maybe not. I bought it from Texas and had it shipped to MA.
If you have hydraulic scarifiers we will not be in the same ball park. Let's just say there are a couple I'm looking at relatively close by that are 450-550. Appreciate the offer though.
Found a 6' Bush Hog 256 with this gear box. 1473383736809.jpg. On the listing the guy thought it was missing a stump jumper and blades [which it ended up having] listed it for $400. However I do need to buy a drive shaft for it. The bushhog sat for 2 years according to him. The gearbox seems to be in good shape after I had spun the blades and the gears got lubed . The more I spun it the more loose and free spinning it became. There might be a possibility of a leak at a seal, but the seals seem cheap to replace if it is a leak. The guy said he believes his workers put grease on spline to remove drive shaft, which he believes it is not a leak. I believe I have found a good deal, but need some thoughts on drive shaft.
Will also accept any opinion or input.
Thanks.
   / Box blade and Rotary cutter #26
A PTO shaft is a commodity item & about $150. Measure the length needed & take note of the shaft size & type on the gearbox then go to Tractor Supply to grab one.
Thanks, Fallon.
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
2002 WACKER RD25 ROLLER (A51222)
2002 WACKER RD25...
2012 Mclaughlin V500LEHD Vac Trailer (A49461)
2012 Mclaughlin...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
