John Deere 2750 3pt won't lift
   / John Deere 2750 3pt won't lift #1
jrv8984
Member
Orwigsburg, PA
John Deere 2750
I bought a John Deere 2750 in the spring. The price was right and it was well taken care of. I knew that the 3pt lift had stopped working. The FEL works fine, the hyd fluid had just been changed w/ new filter. Tractor has a cab.
3 pt will not lift at all, what's the most likely culprit?
Thanks
   / John Deere 2750 3pt won't lift #2
:welcome: to TBN
Does it have a flow control valve that affects the rate-of-drop that may influence 3 pt lift?
   / John Deere 2750 3pt won't lift #3
:welcome: to TBN
2750 has a rate of drop screw under the seat but it does no affect raising of 3 pt.
   / John Deere 2750 3pt won't lift #4
jrv8984
Welcome to TBN
My guess is L/D mechanism is not adjusted correctly. Where is L/D lever under setting at Max or min? I'd suggest to set at "min". It's also possible pressure control valve down by hyd filter is blocking oil to 3 pt. Does tractor have rear breakaway couplers? If so get a 3000+ psi gauge & check stand-by pressure which should be 2250 psi.
Jim
What is the L/D mechanism? When you say break away couplers, do you mean hyd remotes, it has 2 sets, but I don't have a pressure gauge. Don't have an owner's manual for it yet, it's in the mail.
   / John Deere 2750 3pt won't lift #6
L/D stands for load/depth control AKA draft control. L/D lever is key 2 on an open station tractor. Rear breakaway coupler AKA wet lines AKA rear remotes. One can purchase a 5000# gauge for under $20
Manipulating the L/D lever and trying to raise the 3pt does nothing. Don't have a pressure gauge yet.
   / John Deere 2750 3pt won't lift #8
It's possible the pressure control valve close to hyd filter is stuck closed.
Is there another name for the pressure control valve, I'm not seeing that anywhere in my I&T manual.
Any recommendations on a hyd pressure test kit
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
2019 RBR Venturi 380 (A53472)
2019 RBR Venturi...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
(4) 55 Gallon Drums of Bonderite (A51573)
(4) 55 Gallon...
