I'd like to understand grease better.
/ I'd like to understand grease better. #1
AxleHub
Elite Member
Western Wisconsin
Massey scut 2015 GC1715
Grease seems like such a simple thing . . Yet you go into the store and there are numerous choices in the same brand. So it would seem there are reasons to choose one vs. another.
I'd like to learn more about the selection of greases. TYPES of greases more than brands of grease. To use with my sub compact tractor as well as a rider mower etc...
I noticed the exact same brand at the same place I bought it last year on sale . . Is now 20% less than I ever saw it on sale last year.
Its called Mystic JT-6 products and is commonly sold at Tractor Supply and Farm & Fleets and msny other outlets.
The least priced is Multi Purpose grease.
Next for just a couple dimes more is the "red colored" version called Hi-Temp grease.
Finally a couple dimes more there is the "green" version which is Hi-Temp Grease with Moly.
Last time I chose a 10 pack of the Red version because I prefer 1 grease for all my sub compact needs and I figured the mmm greasing needs has a lot more spin related greasing which might benefit from the HI-Temp. And I "assumed" that fel grease points are equally served by the HI-Temp as they would be by the Multi Purpise lower priced offering or the higher priced "with Moly" vetsion.
Opinions desired: Multi Purpose, Hi-Temp, or Hi-Temp with Moly ???
Also, any reasons NOT to use one version or another on all sub compact grease points ??
Here is their website:
Mystik Store - AGRICULTURE - Category Details
/ I'd like to understand grease better. #2
Try this link for starters in learning about lubrication. Every grease type has it's ups and downs when it comes to performance.
Just keep in mind a little often is better than a lot once and awhile and anything is better than nothing.
Machinery Lubrication Magazine
/ I'd like to understand grease better. #3
Havent looked at there products that you linked yet, but you mention key words like high-temp, and moly, etc.
But one important one I didnt see you mention is EP.......Extreme pressure. Thats what you want in a pin/bushing grease. High temp is of little concern in a low speed pin/bushing setup.
Likewise, EP isnt really a concern in mower spindles but high-temp certainly is.
I am not that knowledgable on this new poly urea grease and all, but what has worked for me is a 2-grease plan.
1. I use a synthetic high temp grease, which just happens to be red for high speed bearings. Which in my case happens to be mobile SHC 460 or SHC 32. I use this grease in mower spindles, u-joints, etc. Anything that has high speed bearings.
2. I use a EP grease with moly.....usually this is black in color and a bear to clean off your hands. USe this in low speed high pressure stuff. Loader pins and bushings, backhoe pins and bushings, axle pivots, ball joints, etc. Mobile XHP 322 is a good example of this.
I dont like moly in high speed bearings.
As for a 1 grease fits all......its a compromise with lithium greases. A high temp EP grease, like alot of the red and tacky greases, will work well in both high speed high heat bearings as well as in low speed high pressure applications. I just feel you can get a little bit better going with 2 greases.
And as I said, I am not well versed on this poly urea greases. IF they are better than moly in EP stuff????or better than synthetic lithium greases in the high speed stuff???? or weather they are even compatible with whats already in there???
/ I'd like to understand grease better. #4
I'm no grease guru either. I've used the low priced grease from Tractor Supply on everything and never had an issue. I have switched to the better red grease for my mower spindles like LD1. But again I never had an issue with the lower priced stuff. I use John Deere corn head grease for gear boxes in my brush hogs. It is a flow-able grease. My Brown cutter actually specifies to use it. I remember back in the day all we used was a general all purpose black grease that was packaged in 5 gallon pails. That was the only way we got it. It was a lot of fun refilling your grease guns.
/ I'd like to understand grease better. #5
Frequent greasing with any grease is better than infrequent greasing with the right grease.
Molly is added to various grease types as an EP additive. Makes that nasty black or grey grease that stains everything. It's also what I use on my stuff.
Polyurea seems to be the most popular manufacturer recomendations across the board these days.
Pick one recommended by your equipment manufacturer & stick with it greasing often & you'll be fine.
/ I'd like to understand grease better. #6
The OP wants a multipurpose grease that can cover his tractor and lawn tractor needs with excellent service. His machines seem to have various other greases in them, so compatibility is needed. He wants "the good stuff", he likes getting it at a fair price. Sounds like a lot of us. Deere and Kubota each have, at least for the time being, have come to the same decision; shear stable polyurea. Massey may sell similar, the Lucas green Heavy Duty formulation may be similar. The Deere version, for example, is EP, very water resistant, compatible with most other greases, very high temp resistant, very tenacious (stays put) and recommended for spindles, wheel bearings, pins, U joints -- almost sounds too good to be true. And, it is relatively inexpensive by the carton. Here is a link to Deere's spheal on their greases.
John Deere Grease JohnDeere.com
I purchased a carton from Deere dealer last spring. It has been **** hot and it has not make a mess of my grease guns. No complaints, so far, but I had no problems before other than years ago with Mobil Synthetic dumping the lion's share of its oil out of the gun when not in use. EP lithium complex soap type would be another good choice with wide compatibility and economical. Choices are great, but probably best to be consistent with the type of grease you do choose.
/ I'd like to understand grease better. #7
Use the grease depending upon the cost of the equipment on which you are applying to . I use the grease what the manufacturer recommends so, there is not need for worry. My tractor is John Deere's and I use the their recommended product.
/ I'd like to understand grease better. #8
In the summer of 1958, local boy Danny Zuko (John Travolta) and vacationing Sandy Olsson (Olivia Newton-John) meet at the beach and fall in love. When the summer comes to an end, Sandy, who is going back to Australia, frets that they may never meet again, but Danny tells her that their love is "only the beginning".
Oh, wait... not that grease... :confused3:
I think that "grease" is easier to understand. Than the one I'm referring too lol.
Regarding the lubricating one instead of the entertaining one . . The cartridges describe themselves very similarly yet seem to be for much different types of purposes.
One rather obvious question is . . . Does one type of grease dry up or harden up more than another . . . Which then would imply it could "plug up" a zerk fitting easier or faster ?
Grease seems like such an innocent simple thing . . yet I get the feeling even its frequency of use varies greatly from user to user. Certainly I don't grease anything each time I use it . . . More likely once in Spring again in summer and again in Fall and then once in winter if I use it in winter. That's based on 75 hours of actual use per year or so.
I'm also on the lookout for a zerk connection to my grease guns that allows easier on and of connection that doesn't rely on push and pull pressure. I've seen pictures of it but never seen one in a store.
Also . . though my career has strayed far away from my early training as a machinist and apprentice tool and die person . . I'm ever aware of lubrication factors in most everything we touch . . yet grease seems so overlooked by many . . or at least relegated to the "someday when I get time" perspective.
Here's a simple question: If a type of grease is harder to clean off your hands (or clothes) than another . . Does that indicate it is more likely to :
A. stay working in the zerk applied area
Or
B. Dry up and harden in the zerk applied area or plug it up
Or
C. Will have more resistance to flow well to the desired area
Or
D. Tend to be more water and moisture resistant for outdoor exposure?
I guess I'm trying to apply knowledge or experience from other items to the thinking of grease. With caulk a cheap caulk can be hard to tool or use or it can be "thin" and not last long. Or it can apply easily but harden and not be flexible.
I realize I sound "simple" or like a non-mechanical person when in reality I've just never been around the needs of tractors or farm equipment.
/ I'd like to understand grease better. #11
I use the "red" usually from O'Reilly Auto just because its convenient. Seems like its a Mystic product marked Hi-Temp, EP, NLGI 2 . So far so good. Now can any of you think of a single goodie that will wash any old gob of old hard grease out of the hidden spaces that every prior owner managed to cram some in? Something that won't take the paint off either, just the old grease. I've tried kerosene, diesel, gasoline, engine degreasers/cleaners, etc. but have avoided the brake cleaners, acetone stuff for fear of removing perfectly good paint.
/ I'd like to understand grease better. #12
This is what I use on a lever gun with a flexible hose: LockNLube | Grease Gun Coupler. Free US Shipping over $25
Some old threads: http://www.tractorbynet.com/forums/oil-fuel-lubricants/304889-locknlube-cupler-grease-gun.html
The Review thread: http://www.tractorbynet.com/forums/owning-operating/307933-review-locknlube-grease-gun-coupler.html
/ I'd like to understand grease better. #13
A little tidbit for those of you with a John Deere lawn tractor, the bearings in the deck are sealed bearings, the grease in the spindle housings is to prevent moisture from collecting in the housing, it has nothing to do with lubricating the bearings!
I don't know if this is true with any other brands.
/ I'd like to understand grease better. #14
The Lock 'n Lube is overpriced, just the connector costs more than a whole grease gun. The only thing more outrageous is how well it actually works. I love mine. It's a ripoff, but so worth it.
/ I'd like to understand grease better. #15
A little titbit for those of you with a John Deere lawn tractor, the bearings in the deck are sealed bearings, the grease in the spindle housings is to prevent moisture from collecting in the housing, it has nothing to do with lubricating the bearings!
I was not aware of that morsel of information. Ta.
Oh, and 'green' JD grease (in my green JD grease gun) for both of my rigs.
[I'm not touting JD tools... when I bought my tractors I didn't have all of the maintenance tools & they were right there at my dealership so I bought them. Got a 10% 'owners' discount. :)]
/ I'd like to understand grease better. #16
I too wish I knew more about greases...I love the JD green JD grease for my Deere and the red stuff from Advance Auto seems to work well in both my GMC and the bearings in my utility trailer. The only thing I am concerned about is the how well different brand greases work together. When I last packed the wheel bearings in my UT, I took the extra step of removing ALL the grease in the bearings, spindles, hubs, etc. to be 100% sure the grease I repacked them with would not cause issues by mixing the two. I just purchased a newer UT...it would be so great to learn greases are really compatible. Two newer GM vehicles in our household are sealed suspension and do not require greasing. I am beginning to appreciate that feature.
/ I'd like to understand grease better. #17
What I use... Pretty darn cheap at Ace/Smiths Farm Store too :)
/ I'd like to understand grease better. #18
I'm also no expert on grease. I talked to a guy that works at a wheel and bearing store. He pointed me to "Stay plex" made by CRC. It's a red EP grease. I use it on "everything". No problems to report.
/ I'd like to understand grease better. #19
Here is a good compatibility chart:
The Skinny on Grease Compatibility
You will notice the newer type of polyurea (shear stable) and lithium complex soap based are widely agreeable others. There is little, of any need, to worry about it so long as you use one or the other of these consistently. Now, you guys with that green John Deere;s best multi purpose shear stable polyurea can celebrate your good choice. If you are using your grease in high speed bearings, then there is some concern that moly is inappropriate. Moly is an extreme pressure additive that almost always listed as moly, other EP additives are typically listed on the product label as "EP" ir extreme pressure. I am now using John Deere's best multipurpose green myself. It is easy to obtain at dealer or AMAZON and reasonably priced when buying the carton of tubes.
prs
/ I'd like to understand grease better. #20
my basic grease is John Deere Multi-Purpose HD Lithium Complex Grease - TY24416 about $3.24 a tube
High-quality protection for wheel bearings, U-joints, and other grease points where lithium grease is recommended.
for the bulk of my needs on this old machinery, I would get by on a lesser grease, as most is old steel on steel bearings, "John Deere Multi-Purpose Lithium Gun Grease - PT507" it is about 2.79 a tube, and for the few cents different I figure the first one listed, was to use for my bulk grease so if I do have u joints or wheel bearings not a problem,
and I keep some of there corn header grease around as well,
"John Deere Special-Purpose Corn Head Gun Grease - AN102562"
a semi liquid grease for gear boxes and other places I have used in some trailer wheel bearings, that get seldom used, so the oil runs back into the bearings, started to use it when I had a corn head, but the grease is great on some things,
and I keep a box of the John Deere Multi-Purpose SD Polyurea Gun Grease - TY6341 for the high pressure and high temps bearings, but use it seldom, right now I am not sure where the grease gun is I have for it is tho,
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
UNUSED KJ K0720-7'X20' METAL FARM DRIVEWAY GATE (A60432)
UNUSED KJ...
Tug Boat with Tri Axle Magic Tilt Boat Trailer (A59231)
Tug Boat with Tri...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
42in. Hydraulic Auger Mini Skid Steer Attachment (A59228)
42in. Hydraulic...
