Garage Concrete Slab - Rebar Schedule
   / Garage Concrete Slab - Rebar Schedule
One thing I'm suprised no one has commented on is the 4" thickness. I consider 4" to thin for anything except sidewalk. I'd go with 6" thick. It could be in your area 4" is the norm, you might not have to deal with the freeze thaw we do.
Out here 4" is standard. We have a shallow frost line, around 18", so freeze/thaw is not an issue out here.
One contractor said that #3 rebar at 3 feet on center is sufficient.
Rebar costs = $4.70 per 20' stick (#4) (21x35 pad)
So on a 3 feet on center pad = 19 sticks or $90
On a 1 foot on center pad = 56 sticks or $263
That's a $173 difference
Yet that one contractor said it will cost a "fortune" for the rebar at 1 foot on center. He wasn't talking about the labor but about the rebar. How is $260 vs $90 a "fortune" ?
I could lay rebar myself. It's not rocket science.
Some of these contractor are so full of hot air, it's unbelievable.
   / Garage Concrete Slab - Rebar Schedule #33
Yes about the contractors ^^^. They are like children and need a babysitter to make them do their job.
Plus they ALWAYS add their beliefs and bias into your design plan. Just do what I am paying you to do.
   / Garage Concrete Slab - Rebar Schedule #35
Just install the rebar yourself and use as much as you want. Then let them pour it. ImageUploadedByTractorByNet1475150103.865183.jpg
9.25" pad with fiber, rebar is on a rough 12x12. I didn't fuss with exact measurements just got close. Besides I ended up short 10' so I just devided the remaining section into what I had left. ~15x12 grid. Just poured yesterday so will have to wait to see if it cracks.
Just install the rebar yourself and use as much as you want. Then let them pour it. View attachment 482938
What made you go the 12x12 route? Is that #4 or #3 rebar?
I am going to try this rebar chair instead of using blocks and wire to tie the rebar.
   / Garage Concrete Slab - Rebar Schedule #37
Number 4.
That pad will be home to a feed bin. 7 tons sitting on 4 or 6 legs. I wanted strength. Also added fiber into the 4,000psi mix.
Couldn't find chairs locally to get me close to center of a 9" pour. So drove 24" rebar to 4 1/2-5" then tied to it. Didn't take long at all. Couple hours by myself and that included cutting the rebar.
   / Garage Concrete Slab - Rebar Schedule #38
Number 4.
For strength the rebar should be near the bottom of the slab. This is the tensile stress region of the slab
For crack control the closer the rebar spacing the better, concrete will continue to crack until the crack hits the rebar
The Hercules rebar chair keeps the rebar exactly 1.5" inches from the ground. They are made for 4" slabs. This keeps the rebar down low in the slab, where it needs to be.
Another thing a tighter rebar schedule does is that if the soil/AB underneath moves or sinks, the concrete will span this void without snapping/cracking because the rebar will hold it in tension. Without the rebar, the concrete would snap/crack in this void spot.
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
66in Bucket Skid Steer Attachment (A55851)
66in Bucket Skid...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
2017 FECON RTF140 HIGH PERFORMANCE MULCHER (A52705)
2017 FECON RTF140...
