Tractor Seabee
Elite Member
- Joined
- Oct 5, 2011
- Messages
- 3,902
- Tractor
- Kubota BX25
The axiom "all concrete cracks" is true; the key is to get it to crack where you want it to. That is what control, joints, and expansion joints is all about construction joints. Putting all this in the right places is the key to no cracks in the field of the slab; along with all the other things that have been discussed. I can show slabs (including driveways and parking areas) jobs I have done; 4" thick, 4K PSI, <4" slump, fiber reinforcement, control joints that have no visible cracks for 15-20 years. 2500PSI concrete is OK if the subgrade exceeds that, does not frost heave, does not get overloaded, and stays that way. Not worth taking a chance on. Foundations are static loads not dynamic; big difference. Concrete is an engineered solution not an architectural solution. A lot of architects get it wrong. ACI certs are your best QC.
You can drive a loaded dump truck over a properly placed 4" slab with no problem. Note: concrete is "placed" not "poured", different concept. If you can pour it, it has too much water. Pumped concrete has water reducing additives to keep it thinner with less water. Tell the plant you only want water on the truck equal to the mix design slump requirements, you will provide the was-out water. If your finisher balks at this you have the wrong guy.
Last caveat; saw cutting the next day is wasted money, cracks have already started where you do not want them. Cut as soon as you can get the machine on the slab even if it is midnight.
Ron
Ron
