Replaced oring in loader quick disconnect but it still leaks
   / Replaced oring in loader quick disconnect but it still leaks #1
jobguy
MN
Bobcat CT120
I have a Bobcat CT120 tractor with a model 6TL loader. One of the quick disconnects for the loader leaks (drips) whenever there is no pressure in the system. I have replaced the O'ring a few times over the years and the leak had stopped for awhile until this time, the leak slowed but still drips. I don't have any specs for the O'ring but wonder if a thicker O'ring would stop the leak.
If you are experienced with fixing hydraulic leaks please respond.
Do any of you have a repair manual for a 6 TL Bobcat loader??
Thanks
   / Replaced oring in loader quick disconnect but it still leaks #2
I would start with the easiest/cheapest fix and try a thicker O-ring. If this doesn't fix the problem then either the connection has been damaged or is worn and needs to be replaced.
   / Replaced oring in loader quick disconnect but it still leaks #3
Just wondering if you are using the proper style. Orings come in metric, standard, and different shapes.
   / Replaced oring in loader quick disconnect but it still leaks #4
and material and hardness. It could be the other half of the quick couple is worn where the O-ring seats.
   / Replaced oring in loader quick disconnect but it still leaks #5
Went through that when I bought the present YM186D. O rings from HF and then from Parker Hydraulics didn't help.
I bought new Chinese replica QD's off Ebay at a very reasonable price, problem solved.
   / Replaced oring in loader quick disconnect but it still leaks #6
I have never taken a QC apart, always just replaced. A 25cent Oring would seem like a cheap fix, but if it keeps leaking and you have to keep revisiting the problems, just how much is your time worth
I found an "o" ring set at Fleet Farm with an o'ring size 70-113 that fits and stopped the leak. The o'ring kit with label "Handi-chek 72 Pieces", has the following sizes (70-010, 70-113, 70-116, 70-007, 70-111 and 70-214). 70-113 fits my 1/4 inch fittings. These o'rings are nice and thick. If or when the leak starts again I will update this thread.
Thanks for responding.
Thanks
Ken
   / Replaced oring in loader quick disconnect but it still leaks #8
Little off subject. My Kubota has occasionally dripped since new if parked with absolutely no pressure load on the couplers. 4 years and over 1000 hrs. No replacement.
On subject. Any I've worked on have also had a flat plastic washer next to the o-ring. If yours does pay attention to which side of the o-ring the washer is supposed to be.
2019 CATERPILLAR 259D SKID STEER (A60429)
2019 CATERPILLAR...
JOHN DEERE 744L WHEEL LOADER (A60429)
JOHN DEERE 744L...
2004 Komatsu HM400-1 (A60462)
2004 Komatsu...
2017 GENIE S-45 TELESCOPIC BOOM LIFT (A60429)
2017 GENIE S-45...
2001 John Deere 6210 (A60462)
2001 John Deere...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
