Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins)
/ Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #1
jimpalmer
North Alabama
JD 4052
I recently acquired a used disk. The previous owner pulled it with a Cat 2 tractor. My tractor has Cat 1 three point hitch. I have looked for new pins with the threads of a Cat 2 and pin of a cat 1 (reducing down), but can't find either bushing or new lower arm pins that will fix my problem. I could use the standard cat 1 pins, but the oversize hole will not be stable or last very long on a disk. Anyone solved this problem?
/ Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #2
I have a snowblower intended for cat 2 and I installed cat 1 pins. I think I used a bushing from TSC and cut it to length to make up the difference. Let me look tonight and get back to you. IIRC I used one of these: CountyLine Category 2 to 1 Lift Arm Bushing - For Life Out Here that I cut down. Make sure the cat 1 pins you get have a nice flange and use a large washer under the nut.
/ Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #3
I converted my Cat I implements to Cat II and the bolt holes for the Cat II pins I bought is same as Cat I so all I had to do was remove the Cat I and bolt in the Cat II. Yours should be the same.
/ Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #4
Here're some handy specifications:
/ Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #5
:welcome:
I'm going to move this thread over to our attachments section. :tractor:
/ Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #6
These pins came with my snowblower that is Cat 2 and used as Cat 1 for my tractor:
I temporarily used it on my flail mower but wanted to change the width of the lift arms so made these pins using a Cat 1 pin and two Cat 2 to Cat 1 bushings with washers welded to the bushings:
I fixed the bushings in place with a bolt and pin so the lift arms would not shift from side to side.
Here are a couple more photos:
20160723_Cat2_Cat1_2types_1 (1024x576).jpg 20160723_Cat2_Cat1_2types_2 (1024x576).jpg
The extra washers on mine are to accommodate my Pat's Easy Hitch.
The pins, washers and bushings were in stock at a local agricultural dealer. He also had Cat 1/Cat 2 combinations pins similar to this:
and my cultivator has pins like this:
Search for "cat 1 cat 2 combination pin" to see suppliers.
No, The bolt side or threaded end is larger on HD equipment. Kubota is a medium duty tractor and that type pin is acceptable. However, most HD equipment uses the larger bolt pin (1 1/8") bolt. Check out some Cat 2 pins on HD equipment such as JD, Land Pride, etc. You will see the difference in bolt and nut size. I thought I set out the problem in my post. Sorry if I was not clear. The move to increase from Cat 1 to Cat 2 is available in many forms. Dropping down and filling the larger hole with the threaded bolt and cat 1 pin is where I am unable to find what I am looking for.
/ Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #10
You can use a bushing that is 7/8 ID and 1-1/8 OD to either make a cat 1 pin fit a cat 2 lower arm, or make a cat 1 threaded part fit a cat 2 implement.
/ Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #11
Yes we know what you are asking to do, what they are saying to do is get cat 1 to cat 2 bushings and cut to fit the width of the mounting surface the cat 2 holes are in, then you can use a standard cat 1 bolt on pin. This will bushing the hole from 1-1/8 down to 7/8 to fit the cat 1 pin.
/ Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #12
Here is a tisco part number, if you want to try and order or find them local.
It is indeed. Thank you, had considered this solution but concern about shortening the bushing had me looking for a better option. I may make a jig and use hacksaw in an attempt to get a straight cut.
Thank you Countrybumpkin,
Finally someone with the information I am looking for. Called Tisco, they referred me to dealers near me and I can order part. They are wholesale only, must buy from dealer. No dealer in area stocks part, but will order for me. Getting the part number and supplier is all I needed.
/ Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #15
You may have to bolt them on with the pin facing in, so that your cat 1 lift arms will fit.
/ Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #16
Amazon has them of all places too
Thanks, called Tisco and found a dealer within 10 miles with the part on the shelf.
/ Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #18
For other folks exploring this thread in the future, even more "radical" adaptations are available. My BushHog 286 came with HUGE pins (on the threaded end), but just Cat 1 for the pin itself. The threaded end is maybe 1-1/8" (Cat 3?). I have no idea where BushHog may have sourced these. Maybe Tisco?
Not a great photo, and it is after I installed the cat 1-cat 2 pin bushings for my quick hitch, but you can get an idea of the thread-end size (on the left). Those are 3/4" bolts on the right.
/ Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #19
For other folks exploring this thread in the future, even more "radical" adaptations are available. My BushHog 286 came with HUGE pins (on the threaded end), but just Cat 1 for the pin itself. The threaded end is maybe 1-1/8" (Cat 3?). I have no idea where BushHog may have sourced these. Maybe Tisco? Not a great photo, and it is after I installed the cat 1-cat 2 pin bushings for my quick hitch, but you can get an idea of the thread-end size (on the left). Those are 3/4" bolts on the right.
If it's 1-1/8 thread then it's the same pins listed above.
/ Converting Cat 2 implemnt to Cat 1 (Lower Lift Arm Pins) #20
I think tractorpartsinc.com has the pin that will work for the needed application (1 1/8 thread to cat 1 pin). The part number is HII20-0034 I just ordered 2 for about $24 with shipping and I will follow up if they don't work.
UNUSED FUTURE BK56-56" HYD BACKHOE (A60432)
UNUSED FUTURE...
Schulte XH1500 Series 4 15ft Pull-Behind Batwing Rotary Brush Cutter Tractor Attachment (A59228)
Schulte XH1500...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
2014 Nissan Juke SUV (A59231)
2014 Nissan Juke...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A60429)
2016 CATERPILLAR...
