Removing fence posts with concrete
   / Removing fence posts with concrete #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I need to remove several fence posts that are set in concrete. My tractor has a fel but not forks. Any suggestions regarding best/easiest way to accomplish the task.
   / Removing fence posts with concrete #2
Use the 3 point hitch to start. Probably twice the lifting capacity. Then use the FEL to finish the job and tote the post off.
   / Removing fence posts with concrete #3
The easiest way if you have an auger is to dig a hole beside the post and then pull the post over into the new hole as much as possible and then lift it out. If you don't have an auger you can do it with post hole diggers, sounds a lot harder than it really is.
The way we do it in the trade is to take a bar and split the concrete which allows the post to be extracted most of the time if it is metal. If the new post has to be in the same location then we dig the hole beside the post and pull it. It's just work.
   / Removing fence posts with concrete #5
I've pulled a few for neighbors, one was particulary tough, had to soak it with a hose for a while. If it's metal, put a couple brace bands on it to keep the chain from slipping up. If you have something like a railroad tie handy, you can use that for a lever to increase your lift capacity.
   / Removing fence posts with concrete #6
Where I can't get the tractor, digging a hole alongside is still the easiest way to get the post loose.
Bruce
   / Removing fence posts with concrete #7
If the post is wood, I don't have a tractor around, I screw a short length of wood to the side of the post and use a bottle jack to get it out. If it's metal, I drill a hole through it and insert a bolt with enough sticking out to get the bottle jack under it.
   / Removing fence posts with concrete #10
Wrap a chain as low as you can around the post so it chokes it, run the chain over the top of an old truck wheel and attach it to your tractor and drive. The wheel changes the horizontal motion of the chain to vertical and pulls it up. Not saying you won't have to wiggle it a bit to get it started.
Pulling 4x4 Fence Posts - YouTube .........Mike
   / Removing fence posts with concrete #11
I did it this way, worked great.
   / Removing fence posts with concrete #12
for pulling small trees or tough posts, I remove the attachment from the SSQA, choke the post with an appropriately rated nylon loop and attach to the SSQA plate. Never had a post or small tree put up much of a fight this way.
Removing the attachment gives you more lift force. Shortening the effective loader arm length also gives you more lift. 3pt method good too, just run out of lift travel quickly.
Pretty cool video. I'm definitely going to try that. Thanks for posting.
   / Removing fence posts with concrete #15
I'd use the FEL to push it and get it loosened up a bit then I'd use the 3PT to yank it then back to the FEL to haul it off. Might want to push them all first then yank and haul them one at a time.
   / Removing fence posts with concrete #16
Nice video, but I wonder how well this method works on posts set in concrete, or deeper then two feet, or in solid packed soil?
   / Removing fence posts with concrete #17
Some old variations on the wheel idea, using leverage of a "tongue" on the wheels.
Bruce
May or may not work, but it looks interesting so I gotta give it a try.
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
2015 Forest River Rockwood Freedom S/A Pop Up Trailer (A59231)
2015 Forest River...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A59905)
2019 PETERBILT 579...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
Metal Transport Rack (A59228)
Metal Transport...
