Removing fence posts with concrete
   / Removing fence posts with concrete #11
Use the 3 point hitch to start. Probably twice the lifting capacity. Then use the FEL to finish the job and tote the post off.
I did it this way, worked great.
   / Removing fence posts with concrete #12
for pulling small trees or tough posts, I remove the attachment from the SSQA, choke the post with an appropriately rated nylon loop and attach to the SSQA plate. Never had a post or small tree put up much of a fight this way.
Removing the attachment gives you more lift force. Shortening the effective loader arm length also gives you more lift. 3pt method good too, just run out of lift travel quickly.
Wrap a chain as low as you can around the post so it chokes it, run the chain over the top of an old truck wheel and attach it to your tractor and drive. The wheel changes the horizontal motion of the chain to vertical and pulls it up. Not saying you won't have to wiggle it a bit to get it started.
Pulling 4x4 Fence Posts - YouTube .........Mike
Pretty cool video. I'm definitely going to try that. Thanks for posting.
   / Removing fence posts with concrete #15
I need to remove several fence posts that are set in concrete. My tractor has a fel but not forks. Any suggestions regarding best/easiest way to accomplish the task.
I'd use the FEL to push it and get it loosened up a bit then I'd use the 3PT to yank it then back to the FEL to haul it off. Might want to push them all first then yank and haul them one at a time.
   / Removing fence posts with concrete #16
Nice video, but I wonder how well this method works on posts set in concrete, or deeper then two feet, or in solid packed soil?
   / Removing fence posts with concrete #17
Some old variations on the wheel idea, using leverage of a "tongue" on the wheels.
Bruce
May or may not work, but it looks interesting so I gotta give it a try.
Wooden Swing Bench (A55853)
Wooden Swing Bench...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A55852)
2016 Autocar...
Caterpillar 906M (A53317)
Caterpillar 906M...
(2) USED 3500 LB IDLER TRAILER AXLES (A57192)
(2) USED 3500 LB...
2024 ArmorLite Aluminum End Dump Trailer (A55315)
2024 ArmorLite...
