Couple of Harbor Freight QH questions
   / Couple of Harbor Freight QH questions
Thanks for pointing out the drive shaft extension, today I went shopping for a cat 1 QH, stopped by HF and looked there's over and then stopped by my local tractor supply and they had a countyline cat 1 QH out back that probably has been out there for a few years because the rubber handles were trash and it's not an item that they usually stock because it's not online. When I compared the two you could see the difference in quality, quality welds, thicker steel, and the three hooks were cut clean and square. HF welds not so great and the hooks looked like they cut them with a torch, not square and crooked. HF $99 vs Countyline $279 of course there is going to be a difference, the countyline came with two of the bushings and the connector for difficult top link hook ups, because the handles were trash they sold it to me for $240. I have read many threads about the HF QH and people are having good luck with them and I'm sure they will do the job just fine, if the welds break just pull out the old welder and fix it, you can't beat the price $99. I just thought I would share my observation and shopping experience with everyone, if I didn't find the countyline today I would of bought the HF.
I didnt know HF carried their QH in their stores. I've never seen one in my local store. I ordered one but would probably have got it at the store had I known.
   / Couple of Harbor Freight QH questions #12
Different size HF stores are going to carry different items, I installed my QH today, had to machine the bushings down because they were to long for my tiller, everything went well, after hooking up a few attachments I said heck with this crap I need a QH. California, thanks for the idea of the pins on the top hook, I bought two today. How much swing from left to right should you have your 3pt set to, I have a compact tractor so there is not a lot of room before you hit the tires, should the movement be limited or should there be a lot of swing just stopping short of hitting the tires. TNhobbyfarmer, your really going to like your QH just hooking up my tiller today was simply and easy no more fuss.
   / Couple of Harbor Freight QH questions #13
Implements that are in the ground and can't move sideways need more side slack in the hitch. When you are using implements on top of the ground, most slack can be adjusted out.
Bruce
   / Couple of Harbor Freight QH questions #14
Bruce
Bruce, can you explain why. if I did not have a lot of slack when using my tiller what would happen, would I damage something.
   / Couple of Harbor Freight QH questions #15
My neighbor who is a full time commercial-scale farmer (operates 200 acres of apples and grapes) looked at my setup and advised adjust all the slack out of the 3-point side to side motion. He said he likes everything taut. Seems to me that could be a cause for unnecessary wear so I set it for the slightest possible slack.
The tractor's lower 3-point pins and the PTO are all in line in the same plane. There's nothing that should get tighter as you raise/lower the implement.
   / Couple of Harbor Freight QH questions #16
The way I have learned it is that slack is needed for when you use implements that need slack such as a plow or subsoiler. (2inches of slack)
For example when plowing and there is a rock, the implement can shift sideways to avoid it without bending the implement.
On something like a snow blower or rear blade, some slack is good too (1 inch)because the implement can move away from a root, stump, ice, etc.
Meanwhile then there are implements that you need 0 slack such as a car hitch on your 3point, when towing a trailer or pushing it backwards, you want accurate and a firmer connection.
This wasn't mentioned but the Quick connect will reduce lifting capacity slightly since it moves the pins further back.
On my little sub compact I have an implement that it could barely raise and after adding the quick connect or a pats easy change, it no longer lifts the implement to full height. You have to help the tractor and "lift" the implement by hand to get it up. Maybe only 10-15lbs of assist.
   / Couple of Harbor Freight QH questions #17
That makes sense.
With tree roots everywhere in these orchards, we use only a heavy disk and sometimes a rototiller for cultivation. These will climb over a root without drama.
   / Couple of Harbor Freight QH questions #18
Do a search on "Quick Hitch" on here - tons of great info.
You'll probably want a pair of these - http://www.northerntool.com/shop/to...dware&utm_campaign=NorTrac&utm_content=508701
for each implement. Northern always seems to have the best price and easy shipping.
I went ahead and modified my implements to fit. Just an hour or two of mount point re-drilling and now they all fit either QH or regular 3-pt.
Wow, thanks for the link to the bushing kit. I get sick every time I've bought one at TSC.
However, unless I'm bad wrong (I hope not cause I ordered two of them), the correct version for impliments with 7/8" dia pins is this one http://m.northerntool.com/products/shop~tools~product_200479426_200479426?hotline=false
   / Couple of Harbor Freight QH questions #19
I hope those are the ones for a cat 1 because I just ordered three sets and they shipped today, Im sure they are :D . Being unfamiliar with three points, allowing movement so the implement can work around solid objects sounds logical, I just don't like when I'm traveling with the implement up that it swings side to side. QH will reduce lifting but I'm guessing that the extra weight could be an advantage to ground breaking implements. I was searching for a thread on adjusting a slip clutch drive shaft because I want to try out my new tiller for the first time and did not want to destroy my tractors PTO, searching for threads sure takes up time.
   / Couple of Harbor Freight QH questions #20
Does someone make some kind of pin other than a spiral ring that is a pain to remove every time you want to adjust the 3pt side swing?
LEE G550 MOTOR GRADER (A51242)
LEE G550 MOTOR...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2003 DITCH WITCH 3700 RIDE ON TRENCHER (A51242)
2003 DITCH WITCH...
1995 FORD LT9000 DUMP TRUCK (A51222)
1995 FORD LT9000...
