Snow Equipment Owning/Operating Pictures of your snow weapons
/ Pictures of your snow weapons #3,301
I sure don't want you to be disappointed Roy come on down 6 1/2" of fluffy snow more to fall before midnight... home cook meal venison potatoes gravy veggie home made bread. :)
I appreciate the offer...looks like 5-6 inches so far, and still coming down steady...slows a bit for a while, but than seems to be coming down strong.
I reckon we'll see what we get when it's over...
/ Pictures of your snow weapons #3,302
Well as far as I know we are scheduled for up to 12" but are real close to the 12-18" "line". I went & bought $435 worth of screw in studs. Just played (plowed) in a few inches of snow on top of ice and I am pleased in just 2WD. I put 2 studs in each bar, 160 pc. on the rears and 144 in the fronts. A friend turned me on to a great chain place in Tamworth NH, great chain prices and the studs in stock. A great logger's supply place in general with Husky saws too, Windy Ridge is their name.
/ Pictures of your snow weapons #3,303
Check out a 7' Curtis snow plow blade mounted on our John Deere 3038e - Having fun!!!
Over the last few weeks we have had over 12"+ of snow fall and it's finally time to get our JD 3038e and 7' Curtis plow blade out. After adjusting the feet for the right depth with the gravel and having a little patience with how to properly control the level of the plow this thing makes light work of clearing the driveway (about a .10 of a mile). Check out some footage we shot after a 3" heavy wet snow fell on Christmas Eve. My parents were visiting for Christmas so my Dad got 1st chance at clearing the driveway. I am actually excited about more snow falling on my driveway now.
/ Pictures of your snow weapons #3,304
Yup, good place.
/ Pictures of your snow weapons #3,305
Do you remove those studs in the Spring?
/ Pictures of your snow weapons #3,306
That's my plan. Now that I took on some driveways with roading involved I have not used my good ice chains for 2 reasons. Scarring up the driveways that are paved and premature wear. I was worried that tonights snow might be heavy & wet from earlier weather predictions, so far (5") it's a nice snow and the weather people say the rain/snow line will be only around 5 miles inland.:cool2:
Sorry your snow turned out to be a big tease Roy:thumbdown:
/ Pictures of your snow weapons #3,307
Wasn't bad, actually...about 7" or so of powder, which is great for snow blowing...
/ Pictures of your snow weapons #3,310
I would worry about leaving marks in the driveways... will be interested to hear what you experience with these studs.
/ Pictures of your snow weapons #3,311
I would think a crrbide stud can do some damage to concrete and asphalt just like chains... but not sure about that
/ Pictures of your snow weapons #3,312
Carbide studs will chew up concrete and asphalt, any spinning will leave grooves for sure. My experience comes from carbide studs in snowmobile tracks. I currently run the screw in type which are less aggressive than the more typical thru hole with nut & backer type for snowmobile tracks. Even the screw in types will groove concrete just trying to run the snowmobile out of the building it's kept in if the track spins at all. That's without anywhere close to the downforce a studded tractor tire will have.
About 15 years ago the State of Minnesota tried to ban studs in snowmobile tracks for the damage they were doing to some paved multi-use trails and at paved road crossings. The snowmobile clubs put up a fierce fight and got the stud ban stopped due to the safety they provide the riders.
/ Pictures of your snow weapons #3,313
"beenthere", here are a few more pics from the cab build, and heater, blade
IMG_20141121_163342_696.jpgIMG_20141121_163357_244.jpgIMG_20160112_173103244.jpgIMG_20160216_172203528_HDR.jpg
/ Pictures of your snow weapons #3,314
For chain tensioners I cut strips of large tractor inner tubes to make like a big elastic and simply add 2 hardware store 'S' hooks.
Works quite well and they have lasted many years.
Another option that works is quality bungee cord, again using 'S' hooks. I cut a length somewhat less than the diameter of the installed fitted chains and add about 6 'S' hooks. To create the splice joint I used appropriate tubing and clamped tight in the vice to crimp the ends. Works great.
Challenge is finding quality bungee however but my local flee market always seems to have some and generally lengths up to 20 ft or so.
Something that might also work would be the black rubber straps that sell with 2 'S' hooks if long enough could be found to mimic the diameter of installed chains and then add a quantity of 'S' hooks to bind the chains tight.
While on topic of rubber straps, I resorted to holding down my new battery with them as the factory clamps simply would not fit my replacement battery installation. So far so good as battery has not shifted at all.\
LOL, battery that I had probably could drive the tractor home should I run fuel dry. (like 1200 CC on a 19 hp engine)
Great when you need to cycle plugs a few times more B4 she catches coughs and runs.
/ Pictures of your snow weapons #3,315
I FINALLY had to put on the snow chains. have had aprox 20 inches of snowfall for this part of season. had a 39F day that made it a mess. now its back to 20's and icy.
The tool i got years ago for expanding the springs from tire chain comp[any has always been the downfall on the chain install. I've tries fence stretchers, come along, etc and all have been mixed reviews. Yesterday i had a brain spasm...why not try a ratchet strap.
this method made the job 2-3 times faster for me than previously. the only thing is you have to be real careful when you release pressure. i had no issues, but if your not careful i can see this could cause an issue. i'm going to try and think of a little better way to do this using some other type of ratchet strapping when i have time.
old tool View attachment 493105. this came with my chains. kind of useless as it didnt stretch very far.
This is how i did it this year. i rotated tire with tractor on floor jack, and stretched each connection. worked fast........real fast. Of course you need a step handy. View attachment 493106
Good solution. I have the same tool and have gotten it to work well if I hook it up correctly. I also have a short chain and hook to give it a bit more reach.
/ Pictures of your snow weapons #3,316
I used them last night into this morning and am well impressed with their added bite. I was plowing 24"-27" of snow on mostly ice. The guy I'm plowing for uses them & whatever it does to the surface is ok with him and he's explained to his customers that most of the winter, it's either studs or they can hand shovel it. You can't plow snow if the tires don't propel the machine! My feeling is that prior to the ice, a tractor does not have the gut's to spin a tire on bare pavement, and with only 2 studs in each bar any marking will be kept to a minimum especially with a whole bunch of rubber still hitting the road providing traction where it can. An observant operator is important as well. I'm satisfied that it's a good compromise between limiting normal chain damage, and traction.
/ Pictures of your snow weapons #3,317
I use Trygg studded chains on the rear tires on my M7040.
I blow my two brother's paved driveways using them. I have the tractor but also have the gravel lane.
The only thing you see in the spring is small white dots the size of the chain studs. Like a polished mark.
A few weeks in the sun and they are oxidized like the rest of the driveway.
If you have to use tensioners, consider the metal ring in the center like this photo.
Everything is pulling to the center and not off to either side a bit. Ring is cheap at TSC.
These chains are a home made set of Standard tractor ladder style chains overlaid with Volvo military truck chains.
Dave M7040
/ Pictures of your snow weapons #3,318
Dave M7040
Will be interested in hearing how those two sets of chains work out for you this winter. Hope they do well for you.
/ Pictures of your snow weapons #3,319
Dave those Trygg chains look interesting. When I clear snow, I must travel a total of 13 paved miles, but I'd love a set of chains on my front wheels to hold the plow straight when pushing back snow banks.
/ Pictures of your snow weapons #3,320
neogakai
I'm curious about your 1x3 Fasse valve... do you have a link to a source and more description of how you use it? Pics would be great too.
I tried to post a link but I needed to have 5 posts before i could. Now I guess I can!
2025 MMS MS36C (A53317)
2025 MMS MS36C...
UNUSED KJ K2010 HEAVY DUTY CHICKEN COOP (A60432)
UNUSED KJ K2010...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
1997 DORSEY AIDT-LSCG 53 FT DRY VAN TRAILER (A59905)
1997 DORSEY...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A59230)
2012 Ford F-550...
2018 HINO SA (A58214)
