Chain saw sharpening advice sought
   / Chain saw sharpening advice sought #31
Don't worry about swapping chains. Have an enjoyable afternoon of chain sharpening. Doesn't take that long to swap chains. In the end you will have a large supply of sharp chains that will run you for a very long time with minimal expense!!!!! What's to lose???? :)
   / Chain saw sharpening advice sought #32
I use the dremel chain saw kits and they work great!
   / Chain saw sharpening advice sought #33
With the Timberline, you can put just your bar in the vice with the chain laying in it, you don't need to mount the motor.
I did not know that - I thought for each chain I would have to disassemble (take brake off etc.), take off one chain, mount another chain, put brake back on, and do that 20 times. If I can just put the bar in the vice and drape the chains over that one by one as I sharpen them, well, that changes things a bit. That would also let me take care of any burs on the drive lugs - and I know there are some of those on a couple of chains- caused by my misuse at times. So, now back to the calculator re Timberline with carbide or one of the other options I was about to pull the trigger on. I will look again at Timberline - and see if it takes care of depth adjustment as well, or if I need a separate gauge and file for that.
BTW - most of you likely already know this but while looking at youtube videos re chainsaw sharpening and maintenance I learned you need to lube the sprocket through a hole in the bar - I did not know that.
Raining here all day today so a good day for me to spend time learning about all this while watching football.
   / Chain saw sharpening advice sought #35
I go low tech. I keep sharpening stones in the correct diameter for my chains to fit my dremel. I sharpen on the saw because it's easier to hold and rotate as I sharpen. I mark a link with a sharpie so I know where I started and go around on one side then reposition and go around on the other. Then I make a third round and take a little too much off the rakers. :) My chains seem to cut more aggressive than when new is why I figure I'm removing too much off the rakers. That and I don't bother with a guide on those. As far as angle goes it's pretty easy to position the stone in the existing curve and just hold the dremel steady. Only takes a touch on each one. If I have several chains to sharpen I will remove the sharp and install the dull and do it all over again.
   / Chain saw sharpening advice sought #36
Yes, the Timberline on saw in use or set up on an old bar clamped in vise w/o powerhead for other chains.
My dad always sharpened his chains by hand no problem. Years ago I wondered why he would buy files by the box, so as others have said, if sharpening by hand pitch the old files. I just was not happy with my hand file skills on a consistent basis and over time I felt a little too much variance was occurring. I had seen grinder sharpened chains where the op would burn them or remove half a tooth in one sharpening, so I didn't want to go that route.
Read about the Timberline about five years ago....a pretty slick device that removes very little material and puts a consistent factory edge on each tooth.
Do wear leather gloves if you get one!
   / Chain saw sharpening advice sought #37
OK, Rustyiron and Tompet, looks like I will go with the Timberline. I figure if I get the wife a set of crescent wrenches instead of jewelry for her birthday I will save enough to afford it.
A final question - am I right that I will still need a depth gauge and file to maintain the rakers at the correct height?
   / Chain saw sharpening advice sought #39
Who has tried the Oregon Powersharp system? Thoughts?
   / Chain saw sharpening advice sought #40
I have the timberline sharpener it works great.
I tried sharpening my chain with a file and I stink and can't get the hang of it. That irks me pretty bad because I am very skilled at a lot of stuff and pick things up easy.
But the timberline sharpener makes a chain like new. It takes a little learning.
UNUSED LANDHONOR LHR-EW20000 ELECTRIC WINCH (A54757)
UNUSED LANDHONOR...
2018 John Deere 1653 (A55302)
2018 John Deere...
CATERPILLAR 631G MOTOR SCRAPER (A52706)
CATERPILLAR 631G...
UNUSED LANDHONOR AD-12-23C HYD AUGER (A54757)
UNUSED LANDHONOR...
UNUSED WOLVERINE LL-12-78W 78" LAND LEVELER (A54757)
UNUSED WOLVERINE...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
