Chain saw sharpening advice sought
   / Chain saw sharpening advice sought
Who has tried the Oregon Powersharp system? Thoughts?
I came across a youtube video of that as well. Looks wild - I did see what is inside to see how it works - looked fast but a bit wild.
   / Chain saw sharpening advice sought #42
I have not talked to anyone who has used one but if it works it would be really quick and simple.
   / Chain saw sharpening advice sought #43
Bringing back the edge on an almost new chain by hand in not too difficult after a little practice, however it is much easier to get all the teeth angles consistent with a machine. I also have been looking recently at various types of electric sharpeners. I enjoy sharpening by hand, however my right shoulder, like the rest of me, is getting old and some days is reluctant to file as often as I would like, which is generally after 2 or 3 fuel refills.
There seem to be very variable reports on the various low cost machines that use a disc. Some people are happy with them, others think they flex too much, or are just unpleasant to use. One thing to watch for is that on many you have to clamp each tooth by tightening a screw, then undo it again before moving on to the next. That could turn chain sharpening into a real chore.
The sharpener that appeals to me most for sensible money and what I have ordered is made in the USA by Granberg PRECISION GRINDER (12V) - G112XT - Granberg International. It gets mostly excellent reports and there are some good videos on youtube that show it working
How To Sharpen A Chainsaw Properly - YouTube
Granberg precision grinder and accurate depth guage raker setting for chainsaw chain - YouTube
I bought one of those Granberg grinders last year, I can probably do just a good of job by hand but I like using it. It's gotten to the point where I dont like doing anything unless there's button switches and nobs on it, and since this tool is quick to set up, once you've done it a few times, I pre-fer sharpening my saw with this grinder.
I have a Stanley 12 volt battery booster, compressor, light thing, makes it nice to hook the grinder on to.>>> Amazon.com: Stanley J39 6 Peak Amp Jump Starter: STANLEY: Automotive
   / Chain saw sharpening advice sought #44
OK, Rustyiron and Tompet, looks like I will go with the Timberline. I figure if I get the wife a set of crescent wrenches instead of jewelry for her birthday I will save enough to afford it.
A final question - am I right that I will still need a depth gauge and file to maintain the rakers at the correct height?
Yes, but very easy and not necessary to do every sharpening. I don't remember if there are any YouTube videos on using it. Also, look around online for discount coupon. I found a link on line at the time to a promo on another site and it saved $25 off price, so maybe worthwhile to do a little surfing.
First time set up took a little time, but goes quicker after that...
You brought up the Oregon Powersharp Sharp and I had seen it in the past and it seemed like a gimmick, but this time I went and looked it up on Amazon which had mixed reviews and then on a YouTube video which seemed positive. What I wasn't aware of it seems it is proprietary and you have to also buy an Oregon bar and chain matched to the Powersharp and your saw.
   / Chain saw sharpening advice sought #45
A couple things, one, depth gauges aka rakers are easy. You need to lay a straight edge across the top of each set of two cutters and see how far below that the raker between them is. .025" is what you want. A caliper works for to measure, but after a few times doing it, it's easy enough to eyeball. A Carlton File-o-plate is the best for determining where each raker needs to be, but they're out of production.
Rakers are easily taken down with a flat file, but I prefer a dremel with a sanding wheel or stone. Much less hand cramping.
Lastly, if you don't already grease you bar sprocket, you don't need to start now. Oregon says they do fine with just bar oil lubrication, and that greasing through the hole can actually force grit and grime into the bearings. Some people grease, some don't. I never have, and haven't ever had as problem.
   / Chain saw sharpening advice sought #46
   / Chain saw sharpening advice sought #47
Turnkey, I do intend to do hand filing but don't really want to mount and dismount the 20 plus chains I already have in a box that need sharpening so thought it might be worth it to get those done with a grinder. Then once that task is over I can sharpen by hand on the saw.
BTW which bar mount would you recommend. I am not sure I want to pop for a Timberline at $100 plus carbide files when my chainsaw use is much more limited now?
Yes, changing chains does take a bit of time but not all that much. I have done 8 at one sitting...well, with a coffeee break half way through.
My current one is an Oregon. I am not a fan of the one that sharpens the tooth and the does the depth gauge at the same time. Too many things to watch at once.
   / Chain saw sharpening advice sought #48
I see the point - sort of. But now that I have learned a bit here and from youtube videos I think I can sharpen the chains myself. And what I would not be looking forward to though is mounting and taking off all those chains one by one in order to use the Timberline on each one. I could sharpen the ones that are already off - the first time - with a cheap grinder ($20), and would have 20 chains available which I could thereafter sharpen on the bar as necessary. I am thinking I may never need to buy another chain as each one could then be sharpened many times. For as much as I contemplate using the chainsaw in the future I may only be sharpening a chain once or twice a year.
If I was going to be using the saw a lot I would definitely go for the Timberline. But I guess I could also not sharpen all 20 at once and only do so one by one on the bar as I needed a new chain - I could just mount a new (used) one and sharpen it on the bar.
My usual procedure is to sharpen a chain on the saw when I have used it, change to one that needs sharping and sharpen that to be used the next time. My backlog of "to be sharped" tends to grow during the summer. I cut 10 plus cords a year, need to have about 14 ready to deliver next fall. Already have 10 in the stacks but some still need splitting.
   / Chain saw sharpening advice sought #49
Don't worry about swapping chains. Have an enjoyable afternoon of chain sharpening. Doesn't take that long to swap chains. In the end you will have a large supply of sharp chains that will run you for a very long time with minimal expense!!!!! What's to lose???? :)
Quite true. Using my Oregon 'on the bar' guide I don't even have to look as I file other than to watch for the marked teeth to come around to show when I have finished the chain.
Dream would be a vise on the dining room table so I could watch TV. I suspect someone in my house would tend to object rather violently though.
   / Chain saw sharpening advice sought #50
I did not know that - I thought for each chain I would have to disassemble (take brake off etc.), take off one chain, mount another chain, put brake back on, and do that 20 times. If I can just put the bar in the vice and drape the chains over that one by one as I sharpen them, well, that changes things a bit. That would also let me take care of any burs on the drive lugs - and I know there are some of those on a couple of chains- caused by my misuse at times. So, now back to the calculator re Timberline with carbide or one of the other options I was about to pull the trigger on. I will look again at Timberline - and see if it takes care of depth adjustment as well, or if I need a separate gauge and file for that.
BTW - most of you likely already know this but while looking at youtube videos re chainsaw sharpening and maintenance I learned you need to lube the sprocket through a hole in the bar - I did not know that.
Raining here all day today so a good day for me to spend time learning about all this while watching football.
Most professionals do not lube that sprocket, in fact new bars don't even have a lube hole in them. The figuring is that the chain carries enough oil to lub the sprocket.
UNUSED LANDHONOR LDH-HT380 STAND ON SKID STEER (A54756)
UNUSED LANDHONOR...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2017 Ford Transit 350 Handicapped Van (A55788)
2017 Ford Transit...
Case-IH 370 Steiger (A53314)
Case-IH 370...
2012 Dodge Journey SUV (A53424)
2012 Dodge Journey...
2011 Ford Escape XLT SUV (A54815)
2011 Ford Escape...
