The Trifecta of Attachments
   / The Trifecta of Attachments #31
Welcome to TBN.
Rear blade?
Yes and ty. Last year I moved to a 15 acre horse farm and my job is bldg and grounds. I've got a light duty JD 790 (30hp) and no attachments other than 419 series loader/bucket. Driveway is crushed stone/dirt. I've got a homemade drag, but even with weight it's not cutting down the driveway properly for me to roll it...
   / The Trifecta of Attachments #32
I don't have a favorite brand. I'm a "whatever is worth the money" guy. I always buy used.
As to size, you need to be able to angle the blade 45 degrees and still be wider than your tractor tracks. Might want to experiment with a tape measure or a 2x4 or something similar.
A Box Blade is more aggressive than a rear scraper blade. But if the primary use is driveway maintenance I'd rather have a rear scraper blade.
A Land Plane is a very handy tool for driveway maintenance but isn't capable of doing much else.
Of the three, rear scraper blade, box blade, land plane, rear scraper blade will give you the largest variety of service if only buying one tool.
   / The Trifecta of Attachments #33
Cool, thanks for this insight. Previous owner of the tractor welded 1ft extensions on both sides of the bucket. So I'm just over 7ft wide. I'll do some homework on used implements, appreciate it.
   / The Trifecta of Attachments #34
Do you recommend a particular type? Size? etc?
There are many brands out there. I am saving too buy a Landpride RBT 3584 - it is a beast. Others have mentioned the Landpride 37 series - a little less movement. One thing to remember there are lots of cheap ones out there and they will bend quickly.
Hope this helps
   / The Trifecta of Attachments #35
Hope this helps
That's a good point. You always get what you pay for, problem is used stuff often looks in better condition than it is. Good points here as usual.
   / The Trifecta of Attachments #36
I mostly agree with Overszd, except that for gravel driveway work, a grading scraper requires MUCH less setup and adjusting while you're grading. Almost totally set once and forget. Just drop it and drag it.
   / The Trifecta of Attachments #37
Jimmy in NC. Curious how you reheat the grindings without messing up the plant. Don't you normally heat the rock and then mix in the oil? Seems like melting the grindings would make a real mess over time.
   / The Trifecta of Attachments #38
Nope just a regular rear scraper blade. To crown the driveway I tilt it a bit and angle the blade so the loose material goes to the middle. I do a few passes each way as the scraper doesn't dig in much and then back drag the middle pile with the bucket in float and then pack a bit with the tractor. I do pick off the odd 3"+ rock that comes up but there isn't too many.
I have a 7' box blade which I use to spread new 3/4" crushed gravel but it rips into my base too much to crown with it.
IndyIan, I do pretty much exactly what you do, including a need to toss off the odd large rocks that appear from time to time. Over the years, and having some 3/4 minus added 2 or 3 times, there is a nice base, and the blade (tilted and angled) lets me toss the gravel back in the road and maintain a crown - and a nice crown makes all the difference.
   / The Trifecta of Attachments #39
This sounds pretty close. A rear blade or landscape rake is even better for driveway maintenance if it has a tail wheel / guide wheel. I have a rear blade and a box blade, but what I use most for my 1/2 mile driveway are:
or
   / The Trifecta of Attachments #40
Around here,, they just put it down,,,
and hope the sun will heat and bond it like shingles,,,
I do not know if that works, or not,,,,
AGT Mini Excavator Attachment Set (A50123)
AGT Mini Excavator...
2012 Tiger 130BBL Vacuum Trailer (A53117)
2012 Tiger 130BBL...
2018 GENERAC MAGNUM PORTABLE DIESEL LIGHT TOWER (A51247)
2018 GENERAC...
2016 R and R Products 331 LP Reel Mower (A51691)
2016 R and R...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
WOODS DHS48N LOT IDENTIFIER 184 (A53084)
WOODS DHS48N LOT...
