Chain saw sharpening advice sought
   / Chain saw sharpening advice sought #91
I'd try the Timberline Sharpenerif I could plug it into something, from now on my sharpening tools have to have a motor, although I'd be ok sharpening a chainsaw by hand if the saw only had a 12" bar.
For those who dont have a junk PC for DC power, one of these Stanley Batt. booster works pretty good to power a Grandberg saw shapener, it's what I use, and it has an air compressor for small tires, that works good too.
Amazon.com: Stanley JC59 1 Peak Amp Jump Starter with Compressor: STANLEY: Automotive
Would a typical 12V battery charger work to power the Grandberg sharpener? That is, if set on steady charge and not boost? I already have a couple of chargers and it would be more convenient than pulling my pick up up to the barn/shop and hooking the Grandberg to the pick up battery.
   / Chain saw sharpening advice sought #93
Probably. I have used my old Schumaker on a low (2A) charge setting as a 12VDC power supply. You might want to check the output voltage on yours. Mine runs about 14-15VDC, which I take to be within design limits for a motor built to run from a lead-acid battery.
   / Chain saw sharpening advice sought #96
Yes, a regular manual battery charger will work.
Thanks, that will make it much more convenient to use. My Grandberg has not yet been delivered but I am glad I will be able to power it with my battery charger instead of from the pick up battery - at least when I am not in the field.
   / Chain saw sharpening advice sought #98
I always thought a battery chargers had to be hooked to a battery to be able to power something or it might burn out a 12 volt motor, CB, radio, tape deck....
   / Chain saw sharpening advice sought #99
Frontier FM2015 (A53314)
Frontier FM2015...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 78"...
STEEL SLINGS (A54757)
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
4 Unused Montreal ST205/75R15 Trailer Tires (A53421)
4 Unused Montreal...
Miller Spectrum 500 DC Plasma Cutting System (A54811)
Miller Spectrum...
