Chain saw sharpening advice sought
   / Chain saw sharpening advice sought #91
I'd try the Timberline Sharpenerif I could plug it into something, from now on my sharpening tools have to have a motor, although I'd be ok sharpening a chainsaw by hand if the saw only had a 12" bar.
For those who dont have a junk PC for DC power, one of these Stanley Batt. booster works pretty good to power a Grandberg saw shapener, it's what I use, and it has an air compressor for small tires, that works good too.
Amazon.com: Stanley JC59 1 Peak Amp Jump Starter with Compressor: STANLEY: Automotive
Would a typical 12V battery charger work to power the Grandberg sharpener? That is, if set on steady charge and not boost? I already have a couple of chargers and it would be more convenient than pulling my pick up up to the barn/shop and hooking the Grandberg to the pick up battery.
   / Chain saw sharpening advice sought #93
Probably. I have used my old Schumaker on a low (2A) charge setting as a 12VDC power supply. You might want to check the output voltage on yours. Mine runs about 14-15VDC, which I take to be within design limits for a motor built to run from a lead-acid battery.
   / Chain saw sharpening advice sought #96
Yes, a regular manual battery charger will work.
Thanks, that will make it much more convenient to use. My Grandberg has not yet been delivered but I am glad I will be able to power it with my battery charger instead of from the pick up battery - at least when I am not in the field.
   / Chain saw sharpening advice sought #98
I always thought a battery chargers had to be hooked to a battery to be able to power something or it might burn out a 12 volt motor, CB, radio, tape deck....
   / Chain saw sharpening advice sought #99
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
1990 KME (A55758)
1990 KME (A55758)
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
2010 Ford Transit Connect Cargo Van (A55788)
2010 Ford Transit...
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
