One of the lift cylinder pistons may have come off of the rod.
How do I go about determining if this has happened?
ljPlum,
Before start tearing into it, let's check a few things:
What is the name and model on your FEL valve?
Is the gauge connected to the pressure line from the pump to the FEL valve?
You said that the bucket is working so now can do some testing:
Set tractor RPM at about 1200.
Now curl the bucket till it stops. When it can move no further (mechanically), the relief valve should open. This should be at 2000psi. If it is not, adjust relief valve so that it is (2000psi should be a safe setting for testing).
Now open the bucket till it stops. Relief valve should open at 2000psi.
Now press the lever to raise the FEL. Tell us specifically what happens and what the gauge shows.
Pace Manafacturing 7040What is the name and model on your FEL valve?
Yes.Is the gauge connected to the pressure line from the pump to the FEL valve?
I will do this and report back.You said that the bucket is working so now can do some testing:
On my tractor when the FEL is in floating mode and I turn the wheels fully in one direction, the boom arms are lifting. But it come down as soon as I take my hands off the steering and the boom valve still in floating.
Did you take apart end clean the pressure regulator on the FEL valve, maybe something under the seat?
Did the boom valve section is really in neutral or partly open due to loose, worn or brocken parts in valve end cap?
Now I am going brainstorming. If the IN and OUT of oil flow are mixed, what will be the effect?
Was that FEL ever worked? If yes, what had changed? Slowly or suddently different?
Jacques
If the tractor is an open center hydraulic system, I dont see how the loader valve will ever work the way the picture shows it being plumbed. CAnt just "TEE" things into a open center system. They have to be in series, or use a flow divider/splitter. The divider is after the loader. Hydraulic oil takes the path of least resistance. Which happens to be downstream and through the steering circuit, then return to tank. That explains why the loader aint gettin flow.
MAx out the steering to one direction (calling for more pressure) makes the path of least resistance now the loader. So the oil goes there and that explains why it "somewhat" works with the steering wheel turned all the way.
