Handgun for arthritis
   / Handgun for arthritis #101
SA don't interest me. I am revolver guy. .
hmm... when it comes to SA's.. revolvers got alot of history.
Probably my strongest handgun is a SA.
Magnum research BFR 30-30 chambered in 30-30 winchester.
   / Handgun for arthritis #103
When I was talking about Glocks and 10mm, I figured people knew SA meant semi auto. Glocks are a semi auto, and 10mm are rimless, typically used in a semi auto.
   / Handgun for arthritis #104
Practice and training is great. It will help you when a guy jumps out of the dark, but it is still good to have enough gun. You may not be able to take a good stance, breath and aim.
I know you can kill with a 22. Still not the right tool for self defense, unless it all you can handle or have room for.
Personally I think people who say otherwise are just blow hards, who think to much of themselves.
Better watch out.. you are contradicting yourself. The
The logical conclusion of your statement is that if it is all you could handle OR had room for, then it could be the right tool. Remember what this threads about.
And then you say that people that think otherwise are blowhards.. etc.. except, you yourself have just created an exception for people the sentence before, where it could be the correct tool.
Your post directly contradicted itself.. in the space of 2 lines of text. Congrats!
   / Handgun for arthritis #105
Your comment "unless it all you can handle" tells me enough to know that you would not make a very good instructor for someone just learning about sidearms for self protection. You don't knock people or put them down because they don't meet what YOUR criteria is for a self defense round.
   / Handgun for arthritis #106
So basically you were pissed off enough that you weren't seeing straight, and couldn't differtiate between SG's post and mine, and directed your anger toward me.
Yup.. in medical psychology, thats called:
Berserker-blind rage syndrome: A dissociative disorder where a person reacts violently to something they see, hear or feel.
Sorry you took the heat for me when Zerk disagrees or is angered by the fact that my wife can shoot a gun darn well. ;)
   / Handgun for arthritis #107
Sigarms "took one for the team". :)
   / Handgun for arthritis #108
Oh, I got some guns. Should we start talking hand loads and powder? Ballistics and path?
I'm not sure what that quote was from.. but if from my post, you edited it.
We can certaintly talk handloads and powders and ballistics. I handload everything from 22lr thru 458 LOTT safari cartridges.
I cast, make my own gas checks, bp caps, reload primers, reform brass, etc. The whole enchilada. Ballistic calculators and powder burn charts are everywhere, take your pick.
   / Handgun for arthritis #109
Single action SA and Double action DA and Double action only DAO are also valid terms.. if you are going to use terms with the same acronyms, that could apply to the same guns.. then you need to clearly state what you mean.
A Glock is an interesting design.. it's almost a cross between SA and DAO.. but it's probably safer to say that it is SA with some spring take up by the trigger. ( slide 'partially' cocks the gun, trigger finishes cocking it, then fires it ).
   / Handgun for arthritis #110
Yes he did! And I thank him for his service. ;)
Just getting ready to test out some 507 gr .459 projectiles. I made up some with .0145 aluminum gas checks, and some with .016 copper gas checks, will see if I can tell any difference.
Just getting ready to make some more hard lube too.. getting my beeswax block ready.
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
2022 Polaris Ranger 4x4 Utility Cart (A54811)
2022 Polaris...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A53421)
2018 John Deere...
Kawasaki NR (A50324)
UNUSED RAYTREE RMRB72 - 72" POWER RAKE BUCKET (A54757)
UNUSED RAYTREE...
