New Kubota M7040SUHD or not!
   / New Kubota M7040SUHD or not! #31
This one is fully synchronized. The older center shift version with the dry clutch had the crash box.
Sounds like a great deal if the 4 speed transmission is fully synchronized. The extendable lift arms can be added.
SDT
   / New Kubota M7040SUHD or not! #32
SDT
Hydraulic shuttle plus fully synchronized 4-speed.
Trans shifts good. I do a lot of haulage with it, loads of round bales and dump wagon hauling 5 to 6 ton in it, nice not reaching between your legs to shift.
Extendable lift arms nice but not "needed", I mount 3pt disc mower on and off daily during haying, work good if you unhitch it right! (wouldn't turn down extendable arms.....)
   / New Kubota M7040SUHD or not! #33
I'm an old guy and need extendable lift arms as I no longer try to muscle three point equipment around to hitch up.
Again, sounds like a great deal.
SDT
   / New Kubota M7040SUHD or not! #34
Loader comes off whenever it isn't needed. Some days I've taken it off for a few hours and put it back on later that day, that's how easy it is.
Factory light kit was about $100 per side (two lights) The wiring pig tails are tucked in the ROPS, separate circuit for each side, but you'll need to have a switch, otherwise they are on and off with the ignition. I wired both LED to one circuit and used one switch. Go with Hella :)
I do that too. Several owners here on TBN never take their loader off. Different uses, different expectations. :)
   / New Kubota M7040SUHD or not! #35
Feel's like a sports car with it off:D
Anyone here have Kub's fancy "lever" type hydraulic hitchup that does them all at once? I forgot what the call that option. That's the only part of the procedure that has given me some trouble with pressure in the lines.
   / New Kubota M7040SUHD or not! #36
Good question!!! I don't have it either. I don't believe I have ever heard anyone on TBN talk about having that option and/or how well it works.
Took me a few times to get proficient at removing/installing the FEL. Also to learn how to best avoid line pressure. Beyond the normal, wiggle valves, relieve pressure, etc., biggest thing I've learned is to pay attention to oil temp. Helps tremendously to unhook warm or hot. Worst case is unhooking with cold oil and cool temps. :(
   / New Kubota M7040SUHD or not! #37
This is a pic of the quick disconnect for the loader on my L4060. Works great, no problems!
   / New Kubota M7040SUHD or not! #38
How do you put the lines in and such? How easy?
   / New Kubota M7040SUHD or not! #39
It's really pretty simple. The picture shows the silver handle and that rotates around the female flat face fitting and grabs the male connector and inserts it. It's a quick and simple option and makes removing and installing the loader a breeze.
   / New Kubota M7040SUHD or not! #40
Thanks for the pic Stu. Next time you remove the FEL take us some pics of the process if you remember. Thanks!!!
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2002 Sterling M7500 Acterra Lift-All LA04C51 51ft Insulated Forestry Chipper Bucket Truck (A50323)
2002 Sterling...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2013 BMW X5 xDrive50i AWD SUV (A50324)
2013 BMW X5...
