Cutting rubber horse stall mats
   / Cutting rubber horse stall mats
Thanks all. Carpet knife was $4 at big box store. Comes w 5 blades each blade being able to be rotated to have 2 of not 4 cutting edges. So will try that and the reciprocating saw.
The 2x4 underneath and on top for sure. Got to have a straight(ish) cutting edge.
   / Cutting rubber horse stall mats #22
If I was doing it again, I would seriously consider making the stalls of a dimension that whole mats would drop in without cutting. Not that "dropping them in" is particularly easy either. Everything associated with installing those things I consider a PITA, but I also consider them worth the expense and trouble.
Yeah the problem is that a 12x12 stall is never exactly 12x12 and the 4x6 mat is never exactly 4x6. Plus no matter you are going to have posts to account for.
Just moving them is a pain. However, having been in barns both with and without mats the mat is the way to go. Cleaning a stall with a mat is just a breeze compared to cleaning one without. Not that it is too expensive, but you use less shavings as well.
   / Cutting rubber horse stall mats #24
My experience with 3/4" horse mat cutting has been pretty much all bad. Cutting with a circular saw and/or a table saw at first glance seems to be the ideal way to hack through those mats. And, with the addition of a little WD40 sprayed on during the process, I did get them cut. BUT - cleaning up the now dull blades was not a minor task.
Using a box blade worked pretty good on notches, but does require several cuts to get all the way through the mat. My jig saw with a course blade running a bit slow seemed to work probably the best. You can figure on throwing away any saw blade that you use though.
Horse mats are really great, but all-in-all, they're a pain to cut to fit. Hopefully you'll give us your final judgement on just which method of cutting worked best for youj.
I will report back. Project likely to happen this weekend. Currently I am leaning toward reciprocating saw and just tossing the blade when done.
   / Cutting rubber horse stall mats #26
I've cut many stall mats and tough grain elevator mats and tried everything but the best way I found is with a utility knife, keeping the blade wet with diesel for a lubricant. As long as the blade is wet it cuts easy and the blades don't dull too quick.
Having a helper with a squirt bottle of diesel as you go along makes it much easier.
   / Cutting rubber horse stall mats #28
Rubber mat is 3/4 inch thick. Each piece is 4'x6'. Some will have to be trimmed shorter. Others will have to be notched to go around the stall posts.
One thought is to use a carpet knife.
What about a reciprocating saw? If so what blade? I am thinking for the cuts that have to go the entire length of the mat to chalk a line. Then put a 2x4 under the mat and one over the mat to sandwich it. Use that as a cutting guide and hit it with the saw?
For the cuts around the posts the carpet knife might be needed?
Anyone have any advice?
i've use a fine cut circular, a sawsall with wood teeth, and a jig saw with wood teeth. all worked. circular saw makes a little smoke.. etc.
   / Cutting rubber horse stall mats #29
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2018 John Deere HPX815E (A50123)
2018 John Deere...
2023 EAST TEXAS 40FT GOOSENECK TRAILER (A53426)
2023 EAST TEXAS...
2016 Ford F-250 Reading Service Truck (A51692)
2016 Ford F-250...
2007 VOLVO VHD64 TRI AXLE DUMP TRUCK (A53426)
2007 VOLVO VHD64...
