Cutting rubber horse stall mats
   / Cutting rubber horse stall mats
Thanks all. Carpet knife was $4 at big box store. Comes w 5 blades each blade being able to be rotated to have 2 of not 4 cutting edges. So will try that and the reciprocating saw.
The 2x4 underneath and on top for sure. Got to have a straight(ish) cutting edge.
   / Cutting rubber horse stall mats #22
If I was doing it again, I would seriously consider making the stalls of a dimension that whole mats would drop in without cutting. Not that "dropping them in" is particularly easy either. Everything associated with installing those things I consider a PITA, but I also consider them worth the expense and trouble.
Yeah the problem is that a 12x12 stall is never exactly 12x12 and the 4x6 mat is never exactly 4x6. Plus no matter you are going to have posts to account for.
Just moving them is a pain. However, having been in barns both with and without mats the mat is the way to go. Cleaning a stall with a mat is just a breeze compared to cleaning one without. Not that it is too expensive, but you use less shavings as well.
   / Cutting rubber horse stall mats #24
My experience with 3/4" horse mat cutting has been pretty much all bad. Cutting with a circular saw and/or a table saw at first glance seems to be the ideal way to hack through those mats. And, with the addition of a little WD40 sprayed on during the process, I did get them cut. BUT - cleaning up the now dull blades was not a minor task.
Using a box blade worked pretty good on notches, but does require several cuts to get all the way through the mat. My jig saw with a course blade running a bit slow seemed to work probably the best. You can figure on throwing away any saw blade that you use though.
Horse mats are really great, but all-in-all, they're a pain to cut to fit. Hopefully you'll give us your final judgement on just which method of cutting worked best for youj.
I will report back. Project likely to happen this weekend. Currently I am leaning toward reciprocating saw and just tossing the blade when done.
   / Cutting rubber horse stall mats #26
I've cut many stall mats and tough grain elevator mats and tried everything but the best way I found is with a utility knife, keeping the blade wet with diesel for a lubricant. As long as the blade is wet it cuts easy and the blades don't dull too quick.
Having a helper with a squirt bottle of diesel as you go along makes it much easier.
   / Cutting rubber horse stall mats #28
Rubber mat is 3/4 inch thick. Each piece is 4'x6'. Some will have to be trimmed shorter. Others will have to be notched to go around the stall posts.
One thought is to use a carpet knife.
What about a reciprocating saw? If so what blade? I am thinking for the cuts that have to go the entire length of the mat to chalk a line. Then put a 2x4 under the mat and one over the mat to sandwich it. Use that as a cutting guide and hit it with the saw?
For the cuts around the posts the carpet knife might be needed?
Anyone have any advice?
i've use a fine cut circular, a sawsall with wood teeth, and a jig saw with wood teeth. all worked. circular saw makes a little smoke.. etc.
   / Cutting rubber horse stall mats #29
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A52377)
2008 24ft...
2020 Chevrolet Silverado 3500 HD 4x4 Service Truck (A52377)
2020 Chevrolet...
1988 Kenworth W900B Dump Truck with 3406B CAT (A53473)
1988 Kenworth...
2015 Top Hat T/A 20 ft. Gooseneck Trailer (A53117)
2015 Top Hat T/A...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
